Iconic22F150
I wonder how much Ford would charge to install? Hmm, Ford pass points
part number is 123262 if you have the headlight sensors... purchased here:I cannot find any BDS control arms for the 21-22 year 150s. What model/part number did you use?
Cool thanks Ryanpart number is 123262 if you have the headlight sensors... purchased here:
https://trailsendtruck.com/i-30518154?q=BDS+2022+F-150
Do you think the set you installed would not work for a MaxTow package?I just put a 6112/5160 kit in my shortbed powerboost with standard tow package (NOT maxtow).
I had the dealer set the struts to max height (2.5 in lift) and still have about 1.5 inches of rake. Also added 285/65r20 Maxxis ATs (34.7x11.6 in) on stock sport wheels, and once the wheel well liner was re-installed correctly, it has no rubbing.
IIRC the front now measures 39.5" to the wheel well, and the rear wheel well is 41" from the ground
That's exactly why I inquired with Ford parts about the 5100's.I wonder how much Ford would charge to install? Hmm, Ford pass points.
The ride will change a bit after the first few hundred miles as the seals wear in. Due to the high gas pressure and the way monotubes are constructed, the new seals have a lot of stiction, so small bump compliance is a little "sharp" when new. They should mellow out a bit.Ok, so my 6112 / 5160 were installed yesterday
Not unusual at all for them to settle 1/4" after the first couple hundred miles, so you'll probably end up right at your desired 2". And not uncommon for the rear to lose 1/8" after raising the front due slight change in weight distribution.Rake before was approximately 3.5 inches. My front fender was about 37.5 inches and rear was about 41 inches.
Front is now 39.75 and rear is about 40.75. looks like the 5160 rears may have actually dropped the rear height by a quarter inch.
so I’ve got about 1 inch of rake left. To the naked eye truck looks pretty level…
just providing feedback as I realize all of this is a bit of an inexact science and can vary from truck to truck. if you want to preserve more rake I would suggest the 1.5" setting on the 6112 just to be sure... or set it yourself.... maybe I got 2.5" after all, but I don't think so. my tire pressure was about 30 when I measured the original rake and was 37 when I picked it up from the shop after install.
i called my dealer its 1400 to installI wonder how much Ford would charge to install? Hmm, Ford pass points.
Yeah, likely won't give desired results on those trucks. The diesels have the 5.5' box PB's front struts / ratings. My guess is this set, on the front at least, won't do much for our heavy girls.....We do not recommend this kit for the following models:
Two-wheel drive
high payload package
F-150 diesel
F-150 hybrid
F-150 Tremor
WOW! That's way too much ... not worth it. I have a ton of pass points cause my wife also bought a new car a few years ago and never used them but I just found out it's like 200:1 so not as much as I had thought.i called my dealer its 1400 to install
or 840 for just a level kit to include caster / camber alignment, spacer etc
or 300 to pop out the rear block
"Not validated against F-150 Tremor & 3.5L PowerBoost Hybrid Powertrain"https://performanceparts.ford.com/part/M-18000-F15B
Looks like the M-18000-F15B is "released". ETA currently shows 10/10/2022. They partnered with Bilstein instead of Fox for this one.
Nor will the damping likely be ideal given the heavier rear springs on the PB.Interesting it states, "Not Validated for Powerboost" - if you have a Powerboost/Heavy model you may not get the full 2" due to spring size
As far as I know the max tow just stiffens / lifts the rear, and should work fine. The rear 5160's allow for up to 2 in of additional lift in the rear (blocks or springs, not included). This is part of the reason I chose these over the Falcon's that I was also considering.Do you think the set you installed would not work for a MaxTow package?
