RLTW175
Jim
Dec 30, 2021
109
145
ABQ, NM
23 SCrew, STX 5.0
Fire Starter/Meat Burner turned Sales Guy (but I still light fires)
Yeah, I'll stick with my Rough Country coilover/shock setup that, installed, cost me $800. If its good enough for Hennessy Motorsports, its good enough for me. And after the bullshit I've dealt with on other purchases through Ford Accessories....never again.
Baddeal
Dillon
Apr 22, 2022
60
77
Dallas TX
2022 f150 rcsb 4x4 5.0
Dealership Parts
steeda shows this kit for 1,599 plus free shipping in their site.
Csvt18
Mar 25, 2022
160
64
SE Michigan
2019 f150 SCEW (current), 2022 f150 (ordered)
So what’s that “groove”? Does this allow a 2” level or up to 2.5”?
780
Todd
Feb 2, 2022
1,306
1,094
edmonton
$770 for just the front set of 5100s? Jesus, what a rip off. You can get a full set of front and rear 5100s for around $450 from stage3motorsports and $850 for the 6112 stage 1 front and rear set. They're trying to charge you almost double what the full set (front and rear) of 5100s cost for just the front two lol.
That's good to know. I'll have to check out Stage 3. Side note, that the $770 was in CDN.
hotrodmex
Feb 4, 2022
972
855
Ca
22 Lariat 500.5a
  • Levels truck 2" Front-Rear, with 2.5" front groove available for additional height
That looks to be the case. The normal 6112 has grooves for stock height, then every 0.5" up to 2.5". Notice all the grooves on my pic, and that you can't see any grooves on the kit.
Ford F-150 2021-2023 F-150 Ford Performance Leveling Kit (by Bilstein) is released 1663862741647
Csvt18
Mar 25, 2022
160
64
SE Michigan
So looks like the ford kit is either 2” or 2.5”. No in between.
Wvmtneer
Oct 27, 2020
290
161
Usa
I’d like to know what the actual lift height is for a 157” powerboost. I prefer 1-1.5”, to keep some rake.
thechester
Feb 28, 2022
140
94
MN
2022 F150
It specifically says not for Powerboost. Not quite sure why though.
Ford F-150 2021-2023 F-150 Ford Performance Leveling Kit (by Bilstein) is released 1663867139949
GIjoe
Joe
May 20, 2022
327
224
Ohio
2013 f250
Probably because it won’t get the advertised 2” lift since the Pb is heavier. Same issue with the new fox 2.0 and guys are complaining.
AndrewMC
Andrew
Aug 17, 2022
42
Gray, ME
2021 Powerboost
FF/EMT-B
If it doesn't get the full level on the PB, I wonder if I would be able to fit 295/70R18 on the stock wheels like others with a level report they can. Once I need new tires I'll probably go to my dealer and have them work up a price on installing this, bigger tires, recal the spedo (yes I know Forescan can, but warranties), and align... one big ugly bill.
hotrodmex
Feb 4, 2022
972
855
Ca
22 Lariat 500.5a
The biggest impediment to fitting larger tires is offset. You can fit 35s on a stock offset (+44 - +34), but most pair it with a pokey wheel (+18-0), which changes the scrub radius of the tire to be a larger arc, pushing it into the crashbars.
travisN000
Travis
Sep 13, 2021
301
238
Oregon
2021 F150 Powerboost CCSB
I just put a 6112/5160 kit in my shortbed powerboost with standard tow package (NOT maxtow).
I had the dealer set the struts to max height (2.5 in lift) and still have about 1.5 inches of rake. Also added 285/65r20 Maxxis ATs (34.7x11.6 in) on stock sport wheels, and once the wheel well liner was re-installed correctly, it has no rubbing.
IIRC the front now measures 39.5" to the wheel well, and the rear wheel well is 41" from the ground
Ford F-150 2021-2023 F-150 Ford Performance Leveling Kit (by Bilstein) is released nalr7rcdp6buwhuwcaw_cxucbqdnbioafoy1xwcm-w2400-
93dpscoupe
93dpscoupe
Jonathan
Feb 21, 2022
156
170
Bruceville, Tx
01 GMC 1500, 93 Mustang LX SSP
Product Marketing
Here is the response I received from the tech line:
“The damper is painted and clear coated steel. We do not recommend this kit for the following models:
Two-wheel drive
high payload package
F-150 diesel
F-150 hybrid (powerboost)
F-150 Tremor
The spring rate is proprietary information unfortunately, management won’t let us give that out."
