Hawsa
That tracks. Why use auto high beam and dimming when you have dynamic bending. Nice. So yeah should be pretty much a direct swap with a bit of forscan.
How do I use this tool? I have the lights in and my headlights work so far, my amber drls are on but as assumed I have no turn signal. I tried the mods you gave me but still getting the rapid clicking indication that something is off. I downloaded the comparison tool I just don’t get how to find the raptor info to put into it. Any help you can give is much appreciated.Use this tool and you can put in your as built data from your truck vs a raptor to see the lighting configuration stuff you need to swap
https://www.compulsivecode.com/Project_AsBuiltCompare.aspx
Which headlights did you have before swapping to the raptor headlights? Which raptor headlights do you have?How do I use this tool? I have the lights in and my headlights work so far, my amber drls are on but as assumed I have no turn signal. I tried the mods you gave me but still getting the rapid clicking indication that something is off. I downloaded the comparison tool I just don’t get how to find the raptor info to put into it. Any help you can give is much appreciated.
That's all forscan. You need to make a few changes there. You can use this as a starting guide. It was intended for quad led to raptor so there are more lines than you will actually have to mess with.I have a platinum so I had the projector headlights and the new raptor lamps I have are also the projectors. They work except I can’t get the drl to stay on all the time and be the turn signal. I can have it on all the time or as a turn but not both for some reason.
Did you use the As-Built comparison tool?After a couple of hours last night I finally have the amber drls on all the time however the only way I can get the drl to be used as the turn signal is when I make it set to Stop and Turn in 37-02. It doesn’t seem to work when I choose the turn only option there. So the problem is that the drl only comes on when I’m braking or use the turn signal. Hawsa can you send me your ab so I can compare yours to mine?
