LED REFLECTOR to LED Projector swap discussion.
dolsen
Aug 19, 2022
2,094
1,931
KY
2022 Rapid Red 701A
Did anybody get this sorted? Has anyone tried just hardwiring from quad headlights to projector? I know leveling functionality would be gone but I'm just trying to get my headlights to work with the basic functionalities.
Thanks in advance
It was done in another thread a long time ago, I can’t find it right now, but you literally will only get low beams. No high beams or turn signals without repinning the BCM also
Anon678
Oscar
Jul 11, 2023
Ford F150 2021
I already got the harness from Precision Retrofits but my high beams are always on. Blinkers and marker light works as it should. They don't sell the part of the harness that taps into the fuse box and I dont know where to get it from. Thinking about just making aun auxiliary button with a harness to have my high beams working
dolsen
Aug 19, 2022
2,094
1,931
KY
2022 Rapid Red 701A
Both the lower and upper projector remain on even when running low beams only, as long as you pinned the harness correctly, the turn signals should work.
without the HCM the high beams will not function, nor will the turning, auto level, or glare free
neldiaz
nel
Aug 6, 2022
puerto rico
f150 2021
army
This is for the high beam HCM codes.
can anyone help me? I installed all the parts needed correctly. but when i try to change the codes on the HCM and click write they change back to the numbers/ letters they were before. I followed the instructions correctly.
There is only 1 high beam working correctly.
Any help much appreciated!
THANK YOU IN ADVANCED!!!!!!!!!!
120
8,224
9,445
2022 307a PB, Mach E GTPE
In forscan click NO when it asks about saved profiles and see if it saves when you first connect it.
neldiaz
nel
Aug 6, 2022
puerto rico
f150 2021
army
OK, I made sure to look everywhere else before making a new thread.
I have a 2022 XLT, I made a conversion from bi led to projector led, got both the harness as well as the module from precision retrofits.
I followed their instructions to the letter when installing.... problem is the coding I believe. or the HCM MODULE.
After all was installed, and correctly did the coding only 1 high beam works. the driver side.
The passenger side high beam does not work. but they do light up. Its just the high beam not working.
I did notice that when changing the codes and after trying to save them to the module they went back to the original code. So, I couldn't really save them for the high beam functionality.
Can someone please help get both high beams to work?
I just dont know what else to do.
whoever helps me with this I will pay $100. via paypal.
i prefer to do this over a cell phone.
If not please pm please!! thank you!
Thank you in advance for your help.
dolsen
Aug 19, 2022
2,094
1,931
KY
2022 Rapid Red 701A
I had a very similar issue happen with mine, turned out the conversion harness was pinned wrong. Check continuity from end to end on the harness. I can’t remember which pin I had that was off but if I dig through some of my old posts I may be able to find it. The pin I had that was incorrect I believe got the signal from the HCM to the headlamp motors
neldiaz
nel
Aug 6, 2022
puerto rico
f150 2021
army
Thank you so much for your help!!!!
neldiaz
nel
Aug 6, 2022
puerto rico
f150 2021
army
If anyone have had this problem please help me! lol
dolsen
Aug 19, 2022
2,094
1,931
KY
2022 Rapid Red 701A
MJG44
May 11, 2022
29
702
835
Toronto
22 F150 Black Pack -22 Expedition Stealth - 03 HD
Hope you figure it out.
The Alpharex I installed that went from LED reflector to LED projector also had one plug.in the back of the light. They sell a harness that connects up to factory into the headlight. Works perfect.
Stefanolimotta
stefano
Apr 14, 2022
108
21 f150
Construction
where you able to get it working? I got the same problem. XLT reflector to full led from lariat conversion, Im kind of stuck right now because of this.....
hey did you get it working I’m having a problem with the lights not bending but doing the start up sequence. And low beams turn off when I do the high beams. I have the hcm and harness is it possibly that I pinned them wrong?
120
8,224
9,445
You've been given everything you need to know about fixing it. Responding to people's questions with things like "I can't remember" -- well best remember or load the software up. We're not going to do more work than you're willing to in order to rectify your vehicle.
Stefanolimotta
stefano
Apr 14, 2022
108
21 f150
Construction
your right this weekend Il going to pull the grill of to look at these connections and look a where they were pinned on the passenger side inside the vehicle. Thanks.
