Truck has gotten all OTA's through 4.2.4 without a hiccup. No significant or related DTC's being recorded. Not sure what is going on, tbh.Hi @rugedraw - can you check my sons VIN please. He is having problems with deep sleep, IPC resetting and Bluetooth disconnecting. I am wondering if updates were sent but failed due to low battery. Thanks.
1FTFW1E80NFA53704
1FTEW1EP1MKE27312
Can someone with FDRS provide a list of module updates for this truck?
There is not and there won't be. This is happening to many 2021 trucksthat are still pending older updates. Your last 2.x.x update that failed was 2.7.3, so you don't have the first or second part of the IPC update yet. The good news is, Ford reopened the 21G01 campaign for Bluecruise programming. I would schedule an appt ASAP to get this done with your local dealers before more updates get sent to your truck and possibly complicate things. Or, buy a Mongoose and do it yourself.Would appreciate a lookup of this VIN
1FTFW1ED5MFB63059
We are starting to get updates (got 4.2.1 today), but no Blue Cruise (it's a 2021 platinum powerboost with Prep). Are there any of the 2.X ota updates in the queue?
Thanks a bunch!
Thank you sir! Yeah we are taking it in next week, so I was wondering if we should wait with it in the queue. Hopefully the dealer trip should do the trick.There is not and there won't be. This is happening to many 2021 trucksthat are still pending older updates. Your last 2.x.x update that failed was 2.7.3, so you don't have the first or second part of the IPC update yet. The good news is, Ford reopened the 21G01 campaign for Bluecruise programming. I would schedule an appt ASAP to get this done with your local dealers before more updates get sent to your truck and possibly complicate things. Or, buy a Mongoose and do it yourself.
Edit: Your truck has the 21G01 campaign open under its VIN.
Make you you specify to them that you want to 21G01 campaign performed on your truck. They will not do it on their own.Thank you sir! Yeah we are taking it in next week, so I was wondering if we should wait with it in the queue. Hopefully the dealer trip should do the trick.
Thanks..thinking he has a bad battery and needs it changed out.Truck has gotten all OTA's through 4.2.4 without a hiccup. No significant or related DTC's being recorded. Not sure what is going on, tbh.
Thanks sir...
