Hello, here is my VIN to see where my truck is at with updates. I'm curious about taking advantage of this Android coolwalk
1FTFW1E5XNFC34122
Here you go :Hello, I haven't had an update since August and curious to see what OTA is available. My VIN is:
1FTEW1EP6MKD36178
Thanks!
Thanks!Here you go :
Thank you. Since it's set to auto, why isn't it just updating them?Here you go:
Not all modules can be updated via OTA. APIM's have been pushed in the past, but are slow to be rolled out Ford.Thank you. Since it's set to auto, why isn't it just updating them?
Here is a good post to review about OTA:
https://www.f150gen14.com/forum/threads/request-vin-lookup-thread.13393/post-285615
Several updates for you.I’d appreciate if anyone is able to see if my truck has any pending OTA updates. The automatic update option has been locked off since March of 22. I’ve been to 2 different dealers 6 times to have this fixed and I keep getting the run around. I brought my truck to the dealer this week and they said it was up to date but the auto update option is still locked in the off position.
My vin is 1FTFW1E86MKD06501
Here you go:Good afternoon, can any run my VIN 1FTFW1ED5MFB25363 and see my updates please? Thank you!
Thank you!Several updates for you.
Wow....your truck is very behind on updates. You had 1.4.0 sent to you several times in October and November, but it kept failing. It finally ween through 2 days ago. You may be behind, but the fact you are getting update is good.I’d appreciate it if someone would look up my VIN 1FTFW1E88MFA07469. I finally got an update after a year and a 1/2. Like to know if anything else is going in. Thanks
No OTA history and you are on a very old Sync version. Whatever dealer you took it to at the end of October tried to update your APIM and it failed. They then tried to perform and module repair procedure on it several times but that failed, too. There is a note in there that indicates they called the Ford hotline and got a manual repair code from them. It is also listed in your VIN history that your truck was diagnosed with OTA failure issues and the parts were ordered which I assume is the APIM. You need to follow up with your service advisor to see if the APIM is there and have them swap it out.I’d appreciate if anyone is able to see if my truck has any pending OTA updates. The automatic update option has been locked off since March of 22. I’ve been to 2 different dealers 6 times to have this fixed and I keep getting the run around. I brought my truck to the dealer this week and they said it was up to date but the auto update option is still locked in the off position.
