Yves
Yves
Jun 12, 2022
156
106
Gatineau, Quebec, Canada
F-150 2021 Powerboost XLT 302A 360 Camera 7.2KW
How much did the transfer switch install run you? And how did they overcome the neutral issue I see everyone talking about
I was able to find a transfer switch (Eaton brand) on market place for $200 CDN . The installation, plug for the outside the extra breakers and the 50 feet power cord from the truck to the house cost me $900 CDN. The total is roughly $830 USD. There is no issue with the neutral if you use a proper transfer switch and get it properly installed. The issue is when people try to go around the proper way to do it :)
Dmusick757
Dmusick757
Donnie
May 10, 2021
68
74
Oxford alabama
2021 f150 powerboost xl
Oh ok thats not as bad as I thought. Thank you
Yves
Yves
Jun 12, 2022
156
106
To be honest, the deal on the transfer switch did save me probably between $500 if not $600 CDN. If you look for a used one, please ensure the transfer switch works with bonded neutral. You can always ask for the model and look on the internet to confirm it
AndrewMC
Andrew
Aug 17, 2022
42
Gray, ME
2021 Powerboost
FF/EMT-B
The transfer switch will isolate the neutral so in theory current will follow the correct path to source not freely pick ground or neutral as the path of least resistance. I only have an interlock and 30amp generator inlet on my house. I just made an adaptor pigtail that has the ground unhooked so all current must flow through the neutral.
Ziggy73
Keven
Apr 4, 2022
184
112
76557
2021F150 Powerboost
Radiologic Technologist
I got this power ext cord so I can just have one cord into my garage and then run 4 other ext cords into my house. This one is flat so it goes under the garage door when its closed and the truck is outside. Also I like it because it runs on the 30 amp circuit so both A and B circuit are used for the full 7.2k.
Nice, I have similar, but not for my 30 amp side. I keep it under the seat, you never know when you might need to whoop out the griddle at day use. I love seeing how we are all using it trucks, gives me different ideas.
Cobraman428
Jerry
Dec 21, 2021
311
610
Tampa Bay Florida
2021 F150 Platinum PB 701A MT FX4
VP of IT
Well, I guess I'll be using my PB 7.2kw this coming week. Glad I got the 30amp ext. power cord.
Ford F-150 Real world power outage dealt with using Powerboost ProPower 7.2kw with dropcords 1664024317058
Ford F-150 Real world power outage dealt with using Powerboost ProPower 7.2kw with dropcords 1664024364472
bigjohnp
Jean
Mar 31, 2022
89
72
Quebec
2018 Ford F150 XLT Sport
Fiona is causing huge problems right now through New Brunswick, Easter Quebec, Prince Edward Island, Nova Scotia. Some places got 60 inches of rain overnight, high winds, flooding, lots of damaged buildings and houses.
astrand1
Alex
Dec 16, 2021
771
556
22 Ford F150 Powerboost 7.2kw
Studio truck driver
I did kinda the same thing. I’ve got a 4 pole twist on a 12ft 8/4 cord and a 50 amp Rv plug on the other end. I already had a Rv plug mounted to my shop. Just disconnected the ground. I flip off the mains so as not to back feed power to the grid. Then plug in truck to the Rv plug turn on generator and back feed into the house. Whole setup minus the truck of course was under $100. I know the “safety police” might have a coronary but I’m the only one who hooks it up and make sure I follow a specific order to make sure everything is safe. I just had to use it for the first time last week for about 6 hrs. Tan the entire house without issue. 👍
75
4,559
4,691
2022 302a PB, Mach E GTPE
Create a check list / order of operations for your connection and leave it in the box / connection area. If it's needed in a moment of chaos you'll at least have something to fall back on / proceed without actually thinking about what you're doing.
astrand1
Alex
Dec 16, 2021
771
556
Studio truck driver
That certainly is a good idea. I do have electrical background but one can never be too safe. At some point I’m going to install a different type of system to make it even more full proof but this will work for the moment.
Hullguy
Jim
Oct 14, 2020
379
363
Weymouth, MA
2013 F150 FX 4
Retired Union Electrician
Wrong and dangerous. 38 year master electrician
Hullguy
Jim
Oct 14, 2020
379
363
Weymouth, MA
2013 F150 FX 4
By National Electrical Code you are not supposed to disconnect the ground.
