EricR
No.I have a 8.5x20 enclosed trailer and want to add power. If I get a L14 to L5 adapter like this https://www.amazon.com/L14-30R-Adapter-Generator-Transfer-4-Prong/dp/B081DVVXBX/ref=sr_1_1?crid=1JE31WAWYZVCE&keywords=l14-l5&qid=1655761822&sprefix=l14-l5,aps,85&sr=8-1 and install a L5-30 inlet, will this allow me to take advantage of both A and B circuits in my 7.2Kw PB?
I plan to add A/C to my trailer but right now I just want to add a 30amp breaker and some 120v outlets.
The 30A outlet on PPoB 7.2KW is a L14-30R (receptacle/female). So a L14-30P (pin/male) is needed to connect with it.
Also, any off-the-shelf adapter, dog-bone, cable, etc. that goes from the 4 wires of the L14-30 down to 3 wires (i.e. L5-30) will only give you one of the circuits - either A or B. The other circuit is not connected.
You would need to run 4-wires (Hot: Curciut A, Hot: Curciut B, Neutral, and Ground) back to the trailer to take advantage of both A and B circuits.
Hopefully this reads clearly.
-Eric
