DC in Bed with Pro Power Onboard?
EricR
Eric
Jul 20, 2021
552
591
Boise, ID
Yeah. This is what I’ve been doing. I’ve got a Bluetti AC200MAX which I charge via the AC outlets. This in-turn powers everything else via its DC outlets.
So it sounds like your build doesn't have a dedicated 12V system and battery(s).
Are you using a removable setup like one of the rack-top tent systems?
Davexxxx
Mar 25, 2023
44
701
638
MO
No. I have an FWC ProjectM
I guess I'm trying to understand why?
The Bluetti already has an inverter, converter and storage, all in a pretty small footprint. And its portable and can accept solar charging.
I like a sleek design as much as anyone but what advantage are you trying to gain by having on board DC power in the bed?
Yes, a couple of conversions but the big batt on the PB has to be stepped down, so it isn't directly usable to you anyway.
Samson16
Kyle
Mar 24, 2023
2,106
1,935
Orlando, FL.
Aviation systems
Ok everyone. Conversions are like hoops. Lets jump through the fewest possible please. Run everything you possibly can from AC power. AC everything. For the few things that are DC only get a good quality AC/DC converter without a big battery you don't need. The PB is your "Pure Sine Wave Inverter" only it's 7200W with a built in 3.5L V6 generator!!
Samson16
Kyle
Mar 24, 2023
2,106
1,935
Orlando, FL.
Aviation systems
Carrying all that Solar system weight, cost, and complexity is going to reduce any perceived fuel savings achieved by turning off your PB. Keep the PB fueled up and drinking water becomes the limiting factor for off grid boondocking.
DANNER
DANNER
Dan
Jul 20, 2021
100
46
NorCal
Lariat PowerBoost + FWC Project M
I did use the Pro Power to run everything directly before I got the Bluetti, but it’s really annoying to need to leave the truck on all the time to power anything (especially a fridge). I’ve also got enough DC devices (lights, pumps, fans, etc) to warrant a dedicated DC source.
Pro Power is great, but it’s not perfect for every need.
DANNER
DANNER
Dan
Jul 20, 2021
100
46
NorCal
Well I don’t have a solar system. Just the battery (it is admittedly heavy). It’s pretty simple.
Also, although it doesn’t really concern me personally, but some have remarked that it’s not really a good idea to use your vehicles fuel source to power everything while overlanding, lest you get stuck in the boonies with an empty tank. It’s peace of mind at least.
DANNER
DANNER
Dan
Jul 20, 2021
100
46
NorCal
Well, I asked this question months before I got the Bluetti.
The Bluetti can charge via AC and DC and I imagine charging it via DC could be more efficient. If it were easy to get DC in the bed, I'd probably want to try it.
I'm pretty happy with the setup now though.
Samson16
Kyle
Mar 24, 2023
2,106
1,935
Orlando, FL.
Aviation systems
I'm new to this but wouldn't it be weight better spent on gasoline and fresh water than previously charged up storage batteries? I understand trying to add a solar component, and if you have a decent sized travel trailer you can load it up with a solar system that will stretch out your fuel needs, but if I'm overlanding in the PB I want fuel. Gas is about 6lbs./gallon Carrying more fuel for the PB is the most efficient way forward imo.
Samson16
Kyle
Mar 24, 2023
2,106
1,935
Orlando, FL.
Aviation systems
I get that. I'm planning on having chassis batteries in the trailer to serve that purpose. Perhaps I'm confusing different scenarios. I do that lol
petemill
Pete
Apr 20, 2021
187
155
Santa Barbara, California
'21 f-150 powerboost, '11 ford escape v6
Software
Keeping ProPower on to get AC power for the whole day (say, for a fridge) or to charge the low voltage battery, requires the vehicle being "on" which uses a constant 300W-400W having all the modules enabled. That'll use up the hybrid high-voltage battery in just a couple hours from vampire drain alone. It's more efficient to charge a battery up once per day with ProPower and run appliances from the external battery.
73
4,455
4,587
2022 302a PB, Mach E GTPE
OP, there should be a 12v source at the 7 pin trailer hitch. Not sure of the F150's output but it should be able to deliver 30 or 40a. I strongly advise against using your PB's 12v source w/ out the ICE on, and at that point you're better off running generator mode which enables hybrid operation while also providing significantly more charging power.
Samson16
Kyle
Mar 24, 2023
2,106
1,935
Orlando, FL.
Aviation systems
There are videos of PB's running 25' Airstreams for 24 hours and only using 5 or so gallons. That's AC blasting and everything. If you're in the back of the truck just running a couple LED lights a fan and a small fridge then what maybe 3 gallons a day? Hey, LiFePO4 batteries are surprisingly lightweight by AGM standards. Build a 200Ahr battery bank with a good minder to warn you when it's getting low and enjoy! I plan on using the trailer chassis batteries for keeping things cold in the fridges while we're underway or off in the truck doing things.
73
4,455
4,587
That's way over-doing it -- 3 gallons is about 21kWh worth of energy.
Samson16
Kyle
Mar 24, 2023
2,106
1,935
Orlando, FL.
Aviation systems
Now that plays into my original point that went over like a lead balloon! Just load up on fuel and let the PB do its' thing. Simple and efficient.
