I think the reason for rapid ICE warmup is to maximize traction motor work sharing. The sooner the ICE gets to operating temp, the sooner the desired hybrid load sharing can begin and the more efficient the truck operates.Bottom line the consequences for this mod are 1) hypothetical and 2) have solutions which are being actively engineered for and deployed on the most popular engine in the most popular truck in the world. I think that leads us to the question of: how?
Great idea, and it's exactly what I thought until I looked into the issue further. There's actually a long discussion on this topic earlier in this thread. Bottom line, the heat exchanger is exclusively for cabin heat, with any effect upon warmup time being an afterthought.I think the reason for rapid ICE warmup is to maximize traction motor work sharing. The sooner the ICE gets to operating temp, the sooner the desired hybrid load sharing can begin and the more efficient the truck operates.
The quicker the ICE warms up, the sooner it can shut off. Simple as that.
Where were you yesterday?Cabin heat? wtf?
The cabin doesn't warm quickly enough in the 3.5EB? Good grief.
Did we glean that from some disgruntled former Ford employee who couldn't put the pipe down for the duration of the required company drug addiction program?
Now I'm going to have to read that entire thread.
I think the other big issue is that whenever it's really cold, the ICE stays on. The engine on/vehicle on delta between an auto start/stop 3.5L and a PB is in practice very small, particularly if the PB has heavier tires. In the Aviator hybrid, which has a roughly 2x as powerful electric motor, always wears P rated tires and has a 10x bigger battery, I could see the heat exchanger being a far more important part for warming the drivetrain in a timely fashion.Where were you yesterday?
You take a day off around here?
This place can get a little rowdy (over serious) and you were no help.
Ok, I think you need stronger coffee this morning too.
On the Powerboost, the whole point is to turn that Fire Breathing Twin Turbo OFF ASAP.
The regular 3.5, and 2.7 for that matter, on a frigid cold morning in Fargo, has no intention of turning off.
And we shouldn't forget that since the intention is to turn that motor off, the EPA still has their panties in a wad if you don't get that ICE beyond its fat-rich cold cats cold-start loop soon enough.
T I M E appears to be the essence of that crazy contraption/wart they bolted on to our tailpipe.
So I was pretty close when I said this:Where were you yesterday?
I'm not sure we would even know it's there.I still contend that if it never leaked we wouldn't mind it being there.
I completely agree. I wasn't sure what it was until I saw the leak thread, and even then I thought it was a low temp loop heater for the battery until I was educated.So I was pretty close when I said this:
"The quicker the ICE warms up, the sooner it can shut off. Simple as that."
I was thinking only of efficiency and not overly rich fuel, but for the oil analysis folks lol, is burning that excess fuel off quickly and shutting down a bad thing?
Fascinating. So your answer to the heat buildup while under heavy load(granted typically at higher altitudes while maintaining or exceeding speed limits..) is to insulate the exhaust pipes and reduce restrictions?I completely agree. I wasn't sure what it was until I saw the leak thread, and even then I thought it was a low temp loop heater for the battery until I was educated.
The other reason that I want it gone is my goal of redoing the whole exhaust system AND wrapping the manifolds, turbos and pipes near the transmission. Peak power output is not relevant to real world performance metrics for these trucks, but COOLING absolutely is. I can't easily increase the radiator capacity beyond where it is, but I can try to keep heat in the exhaust pipes and out the tailpipe with insulation AND reduced resistance to flow. My fear is that the electronics and plastic in the heat exchanger would react badly to hotter than expected exhaust temperatures and duly fail at the worst possible time.
