Puffy929
The 2 front side sensors are for active park assist. I.E. automatic parallel parking.Couple of questions. I have a 302A being built but I already bought a 2021 IPMA from a platium that I want will use to add 360 cameras and land keep etc. I do a lot of city driving and parking so would likely build out the truck to whatever the ipma supports.
- Anyone familar with the function of the two front 'side' bumper sensors on trucks that are equipped? It seems this is used for the active park maybe but I wasnt sure?
- Same question on the the front BLIS sensors? Like when are these used and are they typically part of a 302A from factory or something I need to add if I want?
- Does the BLIS sensor use the same front harness or is that a seperate harness - trying to figure out if I get a 6 sensor harness what connects to it?
- On an XLT what is the likelyhood that the harness beyond the front harness would support 6 parking sensors (or even 4)?
Thanks...
The same goes for the front BLIS. They also assist with traffic alert on the front.
I am not sure if they are included with a 302A unless you have it prepped for the active park assist.
I believe the front BLIS uses a different harness that has your headlights going through it. When the front bumper is removed, the headlights stay on the truck.
My 302A had the wires in the engine bay harness for the 4 front sensors up to C1590 on the drivers side engine bay. I had to run wires from that connector to the IPMA. I know it had the wires for the 4 sensors I added but I do not know if it had the wires for 6.
I hope this answers some of your questions and does not add any confusion.
