Adding a Sub to non-unleashed BO system
Graygoose2021
Nov 18, 2021
31
1,892
1,801
Central US!
Sales
well it is a built in powered sub, on hot days, may get pretty hot in there if your jammin
TJSparky
Oct 18, 2021
501
439
WA
There is a small tab you can pull back on. There is some video on it on YouTube. Then get one of these to make it easier to always unlatch…
BuiltRight Industries Rear Seat Release for Ford F-150 (2009+), F-250/350 (2017+) - The Original, Made in USA https://a.co/d/dmHQHVZ
dcfergus
Denton
May 14, 2023
Nashville
2022 F150 xlt
CSFA
hey
Love the clean/simple look of this install! Definitely wanna replicate this, where did you find that mount for the amp and LC2i? Also, mind sharing the deets on what Rockford amp you decided to go with? Thanks in advance man!
TJSparky
Oct 18, 2021
501
439
WA
I used some of this from Amazon and made my own mount.
Mega Format Expanded PVC Plastic Sheets - 11" X 17" Rigid Black Sheet for Crafts, Signage, & Displays - Sintra, Celtec PVC Board - Waterproof for Outdoors Use - 1/4" 6mm Thick - 3-Pk-Black https://a.co/d/fNKhmXE
Amp was a R2500x1
Rockford Fosgate R2-500X1 Prime 500-Watt Mono Amplifier https://a.co/d/dOEbFKz
dewaynetreff
DeWayne
Jun 5, 2023
Basehor, KS
F150 XLT 2023 302A
i figured it out. Anyone installing a subwoofer should change the following in forscan
727-01-01 xxxx x*xx xx--
*A
after changing the parameter, the overall sound and sub level is awesome
Just curious as to what this actually does and why its needed. Thanks!
Jersey devil
Jan 18, 2023
169
129
No. Georgia
2022 XLT
Flattens the sound curve coming from the head unit so your processor/ EQ can fine tune the sound.
When I did my system I just made sure everything was "neutral" in the settings - audio- tone and let the kicker key make the adjustments. Not sure how much of a difference it makes if you went the Forscan route.
Rodoni
Alex
Sep 22, 2022
49
44
EDH
21 F150 Platinum
FF/P
Those running the kicker hideaway…are you using the 10/14 gauge power wire that comes with it and running it to the battery??
Are you using a kicker keyLOC or lc2i and powering it from that dinky wire as well (bridging it from the hideaway to the keyLOC/lc2i)?
I got a 4awg wiring kit to run from the battery but having a heck of a time trying to figure out the best way to attach these small gauge wires to the 4 gauge.
Bob Violence
Bob
Nov 1, 2021
98
125
Houston, TX
2021 F150 Lariat 501A FX4 Powerboost
I ran 10 gauge from the battery to the Kicker. I remember that the power wire included with the Kicker was a smaller wire (larger gauge) than the 10 that I ran, so guessing it is 14 or 16? I am not using a KeyLOC or LC2i, but if I decided to add it later, I'm fairly sure the 10 that I ran can handle the small additional load.
P.C
Paul
Jun 19, 2023
Utah
2023 F 150
You can use a small distribution block. Run the 4 gauge in one side and your smaller gauge wire out the other side.
rugedraw
Javier
Dec 14, 2021
4,524
5,302
Miami
Auto Sales
Well, after three different vehicles and over 5 years of getting its butt kicked, my amp finally decided it has had enough. I bought my Massive Audio N3 monoblock amp over 5 years ago used on OfferUp for $100. I must say, I cannot think of a better $100 I have spent in my entire life.
With that said, I will be replacing it with another MA monoblock that makes a little more power. Not that I need it, but I am a strong believer in making your speakers work harder than your amp. I just ordered this one:
https://www.ebay.com/itm/154727769502?hash=item24067e659e:g:Of8AAOSwsPBhpxTm
Once I get it and wire everything up, I will report back to how it sounds. I am sure I won't be disappointed.
Rodoni
Alex
Sep 22, 2022
49
44
EDH
21 F150 Platinum
FF/P
Those with the kicker keyLOC, did you have any troubles tuning/setting it? I seem to get to the full test part just fine but my lights don’t go with the PDF (IE LED 2 10-20 sec, then LED 3 30-90 sec). It says most finish in 3-8 minutes but after 10 min I’ve still been on LED 3. Just wondering if I have to wait the full 22 min or how long did it take you? I have it tapped into the stock sub wires after the amp, volume 14, settings back to stock, etc.
You’re supposed to install the keyLOC, set it up and then hook up your amp/sub right? Or should I be doing this process with the hideaway connected and running as well?
*edit* ended up trying at 3/4 volume and it went through first try. I was trying to do it at 14 because I saw a post from SGS that said to do it at 14. Now I have to track down why the hideaway isn’t getting power…
BoostIt
Ben
Jul 18, 2023
Oregon
2021 F-150 XLT Powerboost FX4
Okay, so sent the Powerbass door(front w/tweeters, and back door) speakers back a couple months ago. Ordered up Kicker CS(I'd probably go KS after reading the comparisons, but they are quite a bit more, we'll see how after the whole enchilada comes together if I can NOT buy them!) 3-way 6 x 9s for the front door and 6.5's for the rear. Got some used F150 tweeters someone had for sale, and it sounds better. Also have the 3.5" Dayton on the center dash. Front sound stage sounds pretty good(depending on quality of production). Not much low end yet, however, so that, as well as some better sounds quality at higher volumes is next.
Looking to get the Kicker 200.4 next, and was wondering if the wiring with this would be enough for the install, or this would do:
https://www.amazon.com/gp/product/B08BS1RRY8/ref=ox_sc_act_title_1?smid=A3LLMZ9K72U9P2&psc=1
I looked at the wire harness and 200.4 that is on plugnplaykits.com, but it's $480 for the 200.4 and the wire harness. Seeing as how I can get the 200.4 for $279 or so, that seems like a lot(but made easy!).
Lastly, was kind of eye-balling the Ford Kicker 8" sub and box that comes with the 150 watt amp for use of overall installation and space. Prefer not to tear the whole truck up too much(just enough! ;-) ) How much more/less work is the Kicker HS10? I see that's an option too. I'm mainly listening to rock or guitar music, for whatever it's worth. :cool:
Lricaud81
Jun 20, 2023
40
545
192
Louisiana
2023 f150 stx fx4
Have to take time look at all pages I've been wanting to possibly do this. On my long list of wants
