isthatahemi
Trevor
Dec 29, 2021
149
83
2024 Platinum 703a Mag Grey PB
Owner
I dunno, I'd rather run a small generator and let that take the wear and tear than use a $60K+ truck to power my home for that long. I'd be okay with temporary use until you get a portable generator setup or a home generator running, but I'd just keep thinking about my truck running outside.
But let’s say someone has no need for lugging storing and maintaining a generator? Or a dozen other reasons related to convenience….
Sold my Genny when I got my current truck…
Dakar09
Tony
Mar 12, 2024
363
398
Dedham, MA
2024 F-150 Lariat 5.0L
Understood. Still don't think I'd use my truck as a generator for anything but emergencies. Then again, I'm not hip with the latest electrical doodads and hybrid stuff either. I just don't care for it. To each his/her/it's own :cool:
2BigDogs
Jim
Nov 15, 2023
79
85
NH
2024 GMC Denali Ultimate, 2017 MKZ
I have an 8K Generac portable generator that will power the whole house, but is a royal pain to pull out of storage, hook up, etc, etc. During the last snow/sleet/ice storm, I lost power for 4 hours; ran my 7.2 Kw PB for the 4 hrs and used maybe a half to a gallon of gas, if that. Generator would have used 4 gallons. Yep, my truck is the new convenient, economical emergency generator, with the portable Generac as the back up while I drive out to get gas for the "backup" generator. LOL
Dakar09
Tony
Mar 12, 2024
363
398
Dedham, MA
You make good points. I will never deny how annoying it is to wheel out, hook up, and continuously refuel a portable generator. I just worry about the overall quality of new vehicles and putting this extra stress on them for what is essentially "new" technology for daily driven vehicles.
Gorgeous dogs, btw!
scuba
Mar 2, 2022
178
84
Dallas, Texas
'22 F150 Lariat PB Mid Front Bench, 2013 E350 4x4
To me that seems like a lot of fuel for that time period for 500 watts. I have the Powerboost with the 7200 watt version and I ran mine for 48 hours pulling 600 watts. Truck turned on 2-3 times an hour typically for 2-3 minutes each time. I went through 1/4 of a tank.
@labjr1 Did it really runs just 2-3 minutes when topping up the battery? When I sit in my PB to do calls / emails, it seems to run a minimum of 9-11 minutes (and that's with "Eco idle" which theoretically runs higher RPMs to minimize run time).
labjr1
Louie
Aug 23, 2023
194
174
Nashville
2023 F-150 PB Platinum
IT
Yes sir. 2-3 minutes each time. It is all about the power load.
10,626
20,519
As an office, without additional ProPower external load, I experience about 3 ICE charging cycles per hour and each lasting between 1-2.5 minutes.
Ford has definitely adjusted the HV charging parameters (with software updates) over the course of the last 3 years. I say that because originally the HV charging was immediate when the ICE started up. You could see the HV battery receiving ~62 Amps of charging current within a couple of seconds of the engine running. But currently there are times when the ICE will launch and there might be a considerable delay before the charging load is initiated. However long that delay is, determines how long ICE will run before turning back off.
If full charging (60+ amps) begins immediately, the ICE event will last almost exactly 1 minute.
If charging is delayed, and or the charging rate is ramped up gradually, the ICE event gets extended.
2Lazy2P
Apr 24, 2022
320
202
PNW
2022 3.5 EB Platinum 701A FX4 MT
Il Dolce Far Niente
Keep in mind that the 2KW Propwoer is a floating neutral setup.
Can you please explain what this means and how it affects performance? Thanks!
Gros Ventre
Nov 13, 2021
47
2,374
1,590
Western Wyoming
Powerboost
There are two ways a generator can be setup: bonded neutral and floating neutral. In a bonded neutral, as on the 2.4 kw & 7.2 kw, the neutral and ground are bonded together inside the generator. In a floating neutral they are not bonded together. The issue is your house has a neutral ground bond also. When you set up a 2.4 or 7.2 kw to your house it will sense the house bond as a ground and shutdown the generator. On the 2 kW that internal bond was not set up and so the generator will only sense one neutral ground bond and won't trip the generator.
zimmer0
Jun 14, 2022
60
40
DFW, TX
Off topic:
I'm not seeing the 2kw option on the new 2024's. Have they done away with this option? I'd love to have a 5.0L/2kw option.
Djlee1592
Djlee1592
Dave
Jan 19, 2021
226
162
Upstate New York
2021 F-150
industrial mechanic
Off topic:
I think they did
12Lariat21
Jonathan
Mar 23, 2021
498
566
55374
2021 Lariat 502A
Engineering Manager
It is still there, but it is only available on certain packages, standard on some. I think the Platinum non-powerboost get it, the Tremor...maybe only the High Tremeor gets it. I think it's available on the Lariat...but you'd have to play around in the Build/Price tool to see where you can actually get it....
zimmer0
Jun 14, 2022
60
40
DFW, TX
The high Tremor package does have it, i test drove one yesterday with the option. Too bad the Tremor has the inferior front end IMO
