Tire pressure for Michelin Agilis while towing?
macsinbragg
Feb 18, 2021
bragg Creek Alberta
2016 f 150
I am taking off the stock tires and putting on Michelin Agilis cross climate from Costco with a weight rating of 123. I am towing with a 2021 lariat powerboost.
I am towing a 25' Stratus TT with a tongue weight around 600lbs.
Wondering what tire pressure I should have those tires at while towing?
Doyouevenboost
Brian
Mar 17, 2021
196
289
Minnesota
2002 Subaru, 21 f150 502a ecoboost
Utility maintenance worker
Chalk test them while loaded. There are too many variables to give you a definite answer.
B17drvr
Jun 27, 2020
Southeast Texas
20 F150,14Fiesta ST,15 GT350,13 Boss 302,21Mach 1
Pilot
Weigh the truck at a cat scale and inflate according to the manufacturer inflation chart.
Polo08816
Aug 11, 2020
405
221
MD
2014 BMW 335i
I'm interested in your review. I would consider these LRE tires as a replacement for the stock tires.
Chris GTO TT
Feb 21, 2024
Lincoln CA
2023 F-150 XLT 302a
The best way is to do the math. The new tire can carry a little over 42lbs per psi. In order for it to carry the same weight as the stock tire (2600lbs) you'd need about 60psi. Now P-Series tires (like most stock tires) are de-rated by 10%, so you don't need the full 60psi you actually need about 55psi.
Buyer2021
Feb 9, 2021
1,662
2,874
TX
retired!
Not the same tire but perhaps the analysis is of interest ....
Ford F-150 Tire pressure for Michelin Agilis while towing? F150 TIRE INFLATION
All the above weights are from CAT Scale, Load #/Tire is axle weight divided by 2. Tire Rated Max load @ 51psi is from the tire sidewall. The trailer is a small 5th-wheel which has a pin weight of ~800# loaded in the bed directly over the rear axle.
Note that when hitched the rear tire load is essentially the same as the front tire load when not hitched and the front is only 20# more than unhitched.
I experimented with increased tire pressures, felt no gain in handling but got a harsher ride; I'm happiest running at the placard recommended 35psi.
Nothing beats actual CAT Scale data, IMO. You might be surprised at how little additional load is imposed on each tire with your rig hitched, especially if you use a WDH.
