spetaa
- Tom
- Feb 10, 2021
- 0
- 8
- 1
- British Columbia
- n/a
Auto updates isn't grayed out but the toggle doesn't work. Can put on scheduled updates but doesn't seem to work.Seems like your truck was fully updated with FDRS not too long ago. You are only showing updates for the HVAC and door modules.
Your problem goes well beyond the codes you are seeing. Your truck is on Sync 20301 which is bad software from 2020 known to break the OTA process. Are you able to turn auto-updates on, or is it grayed out and the toggle doesn't work? If you can't turn auto-updates off, your APIM will most likely need to be swapped out. Your warranty expired two months ago, so this may be a you problem now if you want to fix it. Your truck has never gotten an update and never will.
Called the dealership at 59,000KM(60,000 warranty expiration) and they said couldn't get me in for a couple weeks, when I went in for the appointment I was over and said if I wanted to change the APIM it would be on me. Sweet timing! I would of assumed they would of had to update/check the modules when doing the recalls/maintenance but I guess not.
