glockcopbob
- Bob
- Mar 27, 2022
- 1
- 42
- 19
- Denver, CO
- 21 F150 Lariat PowerBoost
- Project Manager
The test feature always worked and let’s you reset. this is the same as pushing the test and reset button on the receptacle in your home bathroom and kitchen.Just found this post after successfully getting my Powerboost to run my RV & AC, which suggests that maybe it is a software issue after all? Even so, I'm curious if anyone has done any mods to better waterproof some of the electrical connectors?
"When I perform the self-test, it results in the Ground Fault detected. Ford has issued an SSM 50270 which says this: Some 2021 F-150 vehicles with ProPower Onboard may exhibit a message in the touchscreen stating Pro Power Onboard Turned Off Ground Fault Detected, after performing the Pro Power Onboard test function. This is a normal response after performing the test and full system function may be restored after pressing the on-screen RESET button. Inform customers that engineering is currently working on a solution for this condition and will be released via an over the air (OTA) software update expected in April of 2022."
The actual problem is the system was going into GF without pressing the test button and would not reset. This prevents you from using the power. I could not power anything until the system could be reset. This could be less than an hour or it could be a full day to get the system to reset. Turning off and in the truck and driving around would not make a difference. If anything it made it more annoying; every time you would start the truck, it would display the trip in the screen. This would them send you an email, the app would trigger in my phone, and my watch would trigger. So running errands for an afternoon would send multiple alerts just to remind you that the system is broke.
