Truman
Can you post a site to get this adapter. I have looked and looked and cant find this. it is exactly what i needSomething like this?
Check out this thread, all the information is there:Can you post a site to get this adapter. I have looked and looked and cant find this. it is exactly what i need
I tested this adaptor with my voltage meter. It puts out 120 V from the 220 V outlet. This must mean the cable uses only one of the 120 V feeds on the 4 pin plug. I don't understand why the operating manual cautions not to plug in an RV to the truck.Can you post a site to get this adapter. I have looked and looked and cant find this. it is exactly what i need
If you have a 30 amp plug on your camper 3600 watts is the max you can pull anyway. 120 volts X 30 amps = 3600. some people think they can use a 50 amp pigtail on their 30 amp camper plug and get more than 3600 watts but that is not possible. 30 amps is 30 amps, What I am planning on doing to power my camper is get a splitter for my 240 plug in the truck and just use one of the 120 legs to power my camper. then plug my camper into the converter plug and then plug my camper into that. I have the link to the pigtail and 30 amp extension cord if you need itI’m curious on this. Would like to power a camper with the 7.2kw but not sure if the 220 is needed or if you can run the AC, or get it started with 3.6kw? I’m new to camper AC units. Most of the time there would be a hookup, but this would open possibilities.
that's the one i got. works fine and takes up zero space.
Since that one is fixed and zero flex (like a dogbone allows), what orientation does that force your 30A cord once you twist lock it in? Just curiousthat's the one i got. works fine and takes up zero space.
That cable is so long that it will naturally twist and flex without issue.Since that one is fixed and zero flex (like a dogbone allows), what orientation does that force your 30A cord once you twist lock it in? Just curious
I get that, I was curious if it forces the cord initially down, initially up, or to either side. I think I would want mine forcing the cord up. I have a bed extender I have to swing out of the way and it's tight so I had to get dogbone. May help others decide, if they have obstacles in the bed too.That cable is so long that it will naturally twist and flex without issue.
No. It's such a short adapter that it has virtually zero impact on the cord when plugged in. It's as close to directly plugging the RV power cable into the outlet as possible.I get that, I was curious if it forces the cord initially down, initially up, or to either side. I think I would want mine forcing the cord up. I have a bed extender I have to swing out of the way and it's tight so I had to get dogbone. May help others decide, if they have obstacles in the bed too.
Maybe I'm not phrasing my question right, I didn't think it was this hard to answer.No. It's such a short adapter that it has virtually zero impact on the cord when plugged in. It's as close to directly plugging the RV power cable into the outlet as possible.
What could be an issue is those (like me) with a tonneau cover if you're trying to connect to your RV/Travel Trailer with that cover closed. Might need to create a notch somewhere prior to closing and locking the cover. But that's for another thread!
trying to help.Maybe I'm not phrasing my question right, I didn't think it was this hard to answer.
Perfect! So this sends your cord forward toward the cab. That is probably the best because up would have the cap in the way, facing tailgate forces a sharp bend, and facing down likely also forces a sharp bend.trying to help.
Here is a link to prior thread/photo with the trailer cord plugged in: https://www.f150gen14.com/forum/thr...am-with-gen14-and-propower-7-2.776/post-32864
Here is a picture of my outlet and with the plug in.
Hope that helps.
The cord when I'm plugged in runs towards the cab, and not the tailgate.
Is your camper a 50 amp? Do you have the link to the splitter you mentioned?If you have a 30 amp plug on your camper 3600 watts is the max you can pull anyway. 120 volts X 30 amps = 3600. some people think they can use a 50 amp pigtail on their 30 amp camper plug and get more than 3600 watts but that is not possible. 30 amps is 30 amps, What I am planning on doing to power my camper is get a splitter for my 240 plug in the truck and just use one of the 120 legs to power my camper. then plug my camper into the converter plug and then plug my camper into that. I have the link to the pigtail and 30 amp extension cord if you need it
