Powerboost with no generator?
capetownkg
Apr 22, 2022
125
175
us
2022 F-150, Lariat, PowerBoost, SuperCrew, 6.5’
Has anyone ever seen a powerboost without the generator before. A buddy is looking at trucks and found one and there is no mention of it on the window sticker. He also said the dealer said it didnt have one.
I was under the assumption it had to have the 2kw at the minimum but idk.
capetownkg
Apr 22, 2022
125
175
us
Here is the window sticker
STM
SM
Feb 20, 2022
274
255
Austin, Texas
2010 F 150 XLT
Home Builder
The window sticker says it is a powerboost.. Which means it has an electric motor / generator as well as a 1.5kwh battery..
It can support power draw of up to 2.4kwh...
wayfarer556
Feb 26, 2021
402
774
Austin, TX
2021 F150 XLT Powerboost 302A
You see the little thing that says:
"STANDARD EQUIPMENT INCLUDED AT NO EXTRA CHARGE"?
The 2.4Kw Generator is Standard Equipment for the Powerboost. If Pro Power is not listed in the options list, it's because the 7.2KW option was not elected for the truck.
Source:
I have a Powerboost with the 2.4KW generator.
DarkSkyForever
Dec 29, 2021
347
401
MN
2018 Mustang GT, 2022 F150 701A (Ordered)
Software Engineer
I can't imagine ordering one w/o the 7.2kw. That'd be like ordering a Shelby 500 GT and asking them to swap out the motor for an Ecoboost.
Well, maybe not that extreme, but it does seem to be a commonly equipped option.
10,962
21,444
I'm sure there's circumstances that I haven't thought of, but it doesn't make much sense to me why Ford even offers 7.2KW as optional. I'm not saying $750 isn't $750, but if it wasn't optional it would just be the cost of a Powerboost. :)
daemonic3
Terry
Sep 22, 2020
1,808
1,748
Sacramento, CA
2017 F150 3.5EB
The upgrade is also a payload hit, and people try to pinch "pennies" on those yellow stickers so much as to give up max tow because the gen13 options sheet showed it as a 14# payload hit (even though the best info on it showed it was below-sprung components). (It wasn't until way later that someone inspected under the powerboost and found exact same stabilizers and axles as a max tow EB)
Intuitively, the beefier inverter and way thicker cabling I'd guess are 20# or so but when trying to reverse engineer the 7.2kW upgrade weight, it may be as much as 30-50#.
So if you don't plan to use it, it can save some $ and #.
Maggioa
Anthony
Mar 24, 2021
69
40
Rio Rancho, NM
2021 Mazda CX 5, 2018 Hyundai
Retired Air Force, Currently a Federal Employee
I had an eco boost with the 2kw generator and it was okay for powering crockpots, lights, TVs but it couldn’t run my A/C or microwave in my camper. The issue was the generator couldn’t get pass the initial surge. However, I just turned that truck in for being a lemon (nothing to do with the generator).
I did just ordered a 2023 F-150 platinum without a generator. So the short answer you can get a truck without the generator.
10,962
21,444
I don't believe the Ecoboost comes with a generator of any kind, but rather an inverter that is simply using the 12V underhood battery.
The Powerboost is the only configuration with "generator mode" and comes in 2 inverter sizes. 2.4KW and 7.2KW
You probably could run an RV Air Conditioner with the 2.4KW, but it would require a softstart be installed on the AC.
You can't get a Hybrid F150 without generator mode.
amschind
Adam
Apr 22, 2022
1,086
1,026
'21 F150 SCrew 4x4 Powerboost
Physician
The 7.2kw inverter may be the most useful aspect of the PB. The extra mileage is great, but the ability to power a camper/welder/plasma cutter/big saws et c with a set of unobtrusive plugs in the truck bed is a huge deal. 14# is pretty small payload hit compared to a #150 generator.
MamboMinnow
Frank
Mar 20, 2021
Jacksonville, FL
2021 F-150
I have a PowerBoost with Standard 2.4Kw generator. Rented a camper this summer and I could not run the camper a/c beyond half fan speed or the generator would overload and trip the fuse.
Porpoise Hork
Bret
Aug 27, 2022
1,423
1,487
Houston
IT Sys Admin
With the 2.4KW inverter to avoid overloading it, you would need to put a soft start module on the AC unit to cut the initial amp load by 50-60%. These devices also lower running amp draw by as much as 5-7 amps as well.
