payload question - hauling tile?
cheesedogf150
CheeseDog
Aug 22, 2022
244
190
Toronto, Ontario, Canada
2022 F-150 Lariat
Hello All, quick question about payload.
I'm buying some tile on the weekend - will a skid fit between the wheels wells of a short bed?
The weight of the tiles will be between 1150 and 1380lbs
The payload sticker on my door is 1460 lbs. Anything I should do to prep the truck to carry it, premium fuel? increase tire psi? Will be hauling it about 300km
Thanks!
Davexxxx
Mar 25, 2023
44
707
648
MO
Thanks!
Well, unless you weight less than 6 stone, you should hope for the lighter end of the skid weight.:p
Any possibility you could borrow or rent a utility trailer? It wouldn't take much of one to easily handle that load and then you'd have less risk of being over weight.
75
4,580
4,703
2022 302a PB, Mach E GTPE
Thanks!
You have nothing to worry about. Yes it will fit, yes your weight is fine.
mxwrk
Max
Nov 28, 2022
295
398
Huntington Beach
2022 Lariat Powerboost
I’d make sure your PSI is good and send it!
cheesedogf150
cheesedogf150
CheeseDog
Aug 22, 2022
244
190
2022 F-150 Lariat
I keep it at 36 as per spec, up it to say 40 maybe or keep it at 36?
cheesedogf150
cheesedogf150
CheeseDog
Aug 22, 2022
244
190
2022 F-150 Lariat
I do have a utility trailer and yes it will do 2000 lbs all day long, however I wanted to haul something in the bed that was somewhat significant.
cheesedogf150
cheesedogf150
CheeseDog
Aug 22, 2022
244
190
2022 F-150 Lariat
mxwrk
Max
Nov 28, 2022
295
398
Huntington Beach
I’d air up close to the max, but allow room for expansion when it gets hot. Say 45ish? The maximum says 51 because at 51 that’s the PSI required to handle the maximum load for that tire. Unless I’m wrong lol
JExpedition07
James
Feb 14, 2023
45
1,512
2,372
Buffalo NY
2023 F-150 STX 5.0L V8
You are going to have some serious squat, contrary to what everyone is stating…you won’t be “good and dandy” but it’s just barely doable. She will be on the axle stops or close to it. Did this with my dads F-250 that has double the leaf springs our F-150s do and even that squatted a crap ton. Take it slow around corners etc. and post pics!
WhiteLightningnshitshadow
Feb 24, 2023
46
560
328
Lead Engineer
Yeah the max payload is very conservative. I wouldn't hesitate to put that 1400lbs of tile plus some extra in.
fordtruckman2003
Apr 28, 2023
3,052
2,411
Indy
2021 F-150 FX4 Lariat
Seen many overloaded F-150 over the years. It won't be a happy truck, but it will do the job. Be careful with braking and curves. I agree trailer is better or hope you are at the lower end of the posted weight range.
slow3v
Sep 29, 2022
95
97
USA
It’ll do just fine lol. The payload warriors have most likely never had more than 1k lb in the back.
Davexxxx
Mar 25, 2023
44
707
648
MO
Actually I have and can say that there is a pretty fine line between a truck load of rock and broken springs.
And I've made that, Oh, its just a few miles and I'll go slow,, argument to myself too, while I lean forward in the seat, hoping it keeps the front wheels down enough to steer.
That crap only happens when you either don't know what the weight you're putting on is, or are willing to push the limits and I've done both.
No more and I sure as hell am not going to advise anyone else to take those same chances, with their 50K or better truck, that they might need to go to work in, the next day.
imnuts
Mar 1, 2021
1,501
1,568
Dirty Jerz
'21 502A Powerboost 4×4
Facilities Engineer
I've had my truck over payload twice (once knowingly, other time didn't realize it until after the fact) and it wasn't on the bump stops. There wasn't a lot of room left for rest suspension travel, but there was some.
OP, if it's a short trip, I don't see any issues for you.
