Doggy-Dog
- Ted
- Apr 10, 2021
- 23
- 295
- 191
- Western Michigan
- 2018 Pacifica Limited & 2021 Loaded Lariat
- Retired
KC here and no problems.
Yeah the windshield cowl thing is super soft rubbery plastic that just doesn't seem to fit well. Mine doesn't seem as bad as others tbh, but it still pops up a little.The only “build” complaints I have with my KC truck is “fit & trim”.
And I don’t know that it’s exclusive to Kansas City or maybe just a by product of a “deep into a pandemic” build issue but I am less than impressed with how my door panels line up with the cab & the plastic cover under the windshield wipers, etc...
But… “IT’S A TRUCK”!
And it does everything I ever expected from an American V8 4x4 Truck and a whole hell of a lot more… VERY well I might add!
The plants may operate with the same assembly and QA programs, but that doesn't mean they all produce at the same quality level. Back in the 90's, I spent quite a bit of time at the Ontario Truck Plant. Just inside the main employee entrance there was a bulletin board that showed the latest quality numbers (average repairs per 1000 vehicles) for all 4 F-150 plants. Norfolk was always #1, and Ontario was a distant 4th. I think it ended up closing in the early 2000's when Dearborn Truck was opened.All Ford plants should be under the same assembly and QA programs. Outside vendors will differ by location but audited by the same guidelines. As a life long QA person I know a few things about QA
Ugh, I'd hate to have a body shop peruse my 2022 Dearborn truck. The front/rear door transition on both sides is atroricous, but honestly I've seen worse in pics on this forum. I don't think mine could be fixed with a simple adjustment; either both front door panels are ~1/8" too tall or both rear panels are 1/8" too short. I still look at it every time I approach the truck, but I guess I've leaned to live with it.KC plant with no issues. Working at a ford bodyshop, I seen a new BAP truck come right off the truck from Dearborn with obvious post build damage repaired. The clear coat was blended on the cab corner, and you could see a tape line inside the door. Very shotty to say the least.
Yet Ford closed the Norfolk plant.The plants may operate with the same assembly and QA programs, but that doesn't mean they all produce at the same quality level. Back in the 90's, I spent quite a bit of time at the Ontario Truck Plant. Just inside the main employee entrance there was a bulletin board that showed the latest quality numbers (average repairs per 1000 vehicles) for all 4 F-150 plants. Norfolk was always #1, and Ontario was a distant 4th. I think it ended up closing in the early 2000's when Dearborn Truck was opened.
In all fairness, there can be differences at the plants based on which configurations they build. In the old days, certain plants built certain cab configurations, etc. These can be the source of the quality differences as opposed to the plant workers.
