Hullguy
- Jim
- Oct 14, 2020
- 6
- 379
- 363
- Weymouth, MA
- 2013 F150 FX 4
- Retired Union Electrician
#3. A transfer switch that switches the two hots and the neutral from the house power to the trucks power. There’s a difference between bonding and grounding. The truck will never be grounded due to the rubber tires until you plug it into the generator side of the transfer switch. The earth ground in the transfer switch is hard wired into the houses ground wire. This causes the truck to be grounded to the earth when plugged into the transfer switch@Hullguy, in your professional opinion, which of these would be preferred as "safest" option?
- Use panel earth ground: Create a custom cord from the truck to the panel that does not connect the ground (only populates the hots and neutral in the cord), use standard transfer switch.
- Use truck's ground: Use a standard cord, install a transfer switch that switches all 4 terminals to the truck (effectively disconnecting the panel's earth ground)
From many threads, both methods above appear to work with no ground faults thrown by the truck. My intuition says #1 is safer (built in lightning protection) but I'd love to hear from an expert and understand why!
(full disclosure - I don't plan to do any of the above, my power has never been out for more than about 5 minutes in 12 years, we don't have extreme weather, and local power is all underground)
Sorry for the delay. Life! Part of the problem is that a bond is not a ground.@Hullguy, in your professional opinion, which of these would be preferred as "safest" option?
I would g o for option #3. This is where the transfer switch switches the 2 hot legs and the neutral to the trucks power. the ground is never switched! In fact, when the truck is plugged into the transfer switch the truck becomes grounded with the house ground.
It's the two bonded neutrals from the truck and the house tied together that cause the ground fault
Pretty good explanation. https://www.electricgeneratorsdirec...ipping-a-Generator-With-a-Bonded-Neutral.html
Good explanation on how a transfer switch transfers the house neutral to the trucks neutral without a GFI trip. https://www.wincogen.com/knowledge-...i-protected-generator-with-a-transfer-switch/
This stuff gets confusing as hell! Hope I am helping out. Jim
