22Platinum
can anyone elaborate on this?Sirius XM delete
A good chunk of the 22 trucks have both navigation and sat radio deleted. Some only had nav deleted and actually had sat radio since that is done in the ACM and not the APIM.can anyone elaborate on this?
Oh dang I was hoping someone knew a Forscan to delete SiriusXMA good chunk of the 22 trucks have both navigation and sat radio deleted. Some only had nav deleted and actually had sat radio since that is done in the ACM and not the APIM.
I would imagine it is possible to remove SiriusXM as a source using Forscan. I think you would do the opposite of those of us that have added it back in (myself included).Oh dang I was hoping someone knew a Forscan to delete SiriusXM
Its from both lol. It will display the speed limit based off gps, but then update and change if it reads a different speed limit from a sign.Wait so that stupid little MPH thing is from camera recognition?
I thought it was from Nav in your truck?
'Such and such road is 35mph', so it just tells you...?
Learned a new thing today...
After some reading I think im going to skip the attempt at enabing the Sign Recognition due to the lack of navigation. With that said do you think the turn by turn changes will still work if I just change those two values?
720-05-01 xxxx x1xx xx—
720-10-01 xxxx xx4x xx—
The bolded settings for 7D0-01-01 are what I used to disable SiriusXM and ignore any DTCs it might generate:Oh dang I was hoping someone knew a Forscan to delete SiriusXM
I haven't found a way to do it for Google mapsI’m wondering if this will work with google maps? It seems my truck only shows the turns and stuff on the Speedo cluster for Apple Maps, but not google maps.
If you have built in navigation, your values will be different as it’s going to get info from the navigation unit as well as the front camera. These changes were for those that do not have navigation or had it removed due to chip shortages.So after upgrading my '23 STX with the 8" cluster I've messed around a bit to get the speed sign recognition working. Right now the speed limit comes on white after passing a sign then grays out and goes away sometimes. I also noticed that it's not on the nav screen anymore. Am I doing something wrong. I followed the codes posted earlier.
I do have nav. So do you know where I would be able to find the correct ones. I've been searching without much luck. I've been trying to use the spreadsheet but can be difficultIf you have built in navigation, your values will be different as it’s going to get info from the navigation unit as well as the front camera. These changes were for those that do not have navigation or had it removed due to chip shortages.
706-02-01 *XXX XXXX XX— is where you want to check. The other lines should be the same. We’re using 5 for our non-nav trucks. 6 or 7 will change the mode to “fusion” and will use data from the nav unit as well as the camera. You’ll have to check the spreadsheet to make sure your other features remain the same while turning fusion on to determine if you should use 6 or 7.I do have nav. So do you know where I would be able to find the correct ones. I've been searching without much luck. I've been trying to use the spreadsheet but can be difficult
Right on I appreciate that. I will have a look. Thank you706-02-01 *XXX XXXX XX— is where you want to check. The other lines should be the same. We’re using 5 for our non-nav trucks. 6 or 7 will change the mode to “fusion” and will use data from the nav unit as well as the camera. You’ll have to check the spreadsheet to make sure your other features remain the same while turning fusion on to determine if you should use 6 or 7.
