- Bruce
- Jun 19, 2021
- 4
- 9,040
- 16,383
- Coastal Texas
- 2022 F150 KingRanch Powerboost
Here's hoping that the DSP update was patched too. I'm gonna install the GWM update then re-try the DSP update.New OTA jsut released. Hit my truck today.
It is available in FDRS as well Gateway Update. I do not know the OTA version Number
Seems to be 2021 only at thispoint. COuld be wrong but the vins I pulled for 22 didnt show the update
I had the same idea myself. No joy. GWM installs fine (although I never saw the “update successful“ screen prompt after restart). DSP is unchanged. It reinstalls but does not clear the queue.Here's hoping that the DSP update was patched too. I'm gonna install the GWM update then re-try the DSP update.
Same, but I also think that DSP doesn't actually install on my Job 1 2021 based on the software component numbers.I had the same idea myself. No joy. GWM installs fine (although I never saw the “update successful“ screen prompt after restart). DSP is unchanged. It reinstalls but does not clear the queue.
I thought that too. But I was wrong. According to the Motorcraft as-built database and FDRS, it looks Ike the update didn’t go through. But if you look at FORScan, you should see an updated software version.Same, but I also think that DSP doesn't actually install on my Job 1 2021 based on the software component numbers.
Mine are below. I don't know how to interpret any differences, but both seem the same.I thought that too. But I was wrong. According to the Motorcraft as-built database and FDRS, it looks Ike the update didn’t go through. But if you look at FORScan, you should see an updated software version.
I guess not even FDRS reads module data directly from the truck itself but looks to the server once it captures your VIN.
You’re right. It doesn’t look like yours updated. F188 in FDRS and the Strategy in FORScan are the same. On mine, I see ML3T-14C589-BH at F188 on FDRS and Motorcraft. On FORScan, I see ML3T-14C589-BN for the strategy.Mine are below. I don't know how to interpret any differences, but both seem the same.
Here's what Forscan shows:
DSP - (Audio) Digital Signal Processing Module
Part number: ML3T-18B849-AH
Calibration level: ML3T-18B849-AH
Strategy : ML3T-14C589-AJ
Here's what FDRS shows:
DSP - Audio Digital Signal Processing Module
- No DTCs Detected
- DID F18C - 4027754144170038
- DID F10A - ML3T-14C656-AJ
- DID DE01 - 1C
- DID DE00 - F40D80
- DID F111 - H1BT-14F171-AB
- DID F166 - 15012733
- DID F15F - 08080001210075020000
- DID F110 - DSH1BT-18B849-AR
- DID F113 - ML3T-18B849-AH
- DID F163 - 03
- DID DA01 - ML3T-18B849-AJ
- DID F109 - 785631
- DID F188 - ML3T-14C589-AJ
- DID DE02 - 03
- DID F161 - 021902
- DID F160 - 061502
Yup. That was it. Strategy now shows ML8T-14C589-AB.You’re right. It doesn’t look like yours updated. F188 in FDRS and the Strategy in FORScan are the same. On mine, I see ML3T-14C589-BH at F188 on FDRS and Motorcraft. On FORScan, I see ML3T-14C589-BN for the strategy.
To be sure of what you’re getting in FORScan and that the results reflect recent changes (if any), make sure you aren’t using a saved profile.
For better or worse, you are up to date.Yup. That was it. Strategy now shows ML8T-14C589-AB.
Ok so maybe that wasn't just me. We had some weather last night and I could not for the life of me get it to pull up. Anyone else verify that it doesn't work?I installed the latest GWM update via FDRS, and I did need to manually reboot Sync one more time to get GPS/cloud connectivity back. I did notice however that some update over the past couple weeks must have broken the ability to view weather radar on the Nav system (current weather still works - the issue is just with radar imagery).
I'm wondering if anybody can lookup my vin for updates on fdrs. I got a mongoose, and a fdrs license and updated everything I could. Now the license is out and I returned the mongoose.
I think Sync is STILL not fully up to date. Which is quite annoying... I didn't realize APIM might need multiple updates.
1FTFW1ED9MFC06494
Thank you anybody!
