Adding Auto Level to Projector Headlamps
superfordman
Troy
Jun 29, 2021
806
770
NE CO
2023 F150 Lariat 501A
Precision Ag Guru
Crap, I just realized I didn't order the connectors for the wiring. Does anyone know how to cross reference Ford part numbers into Molex part numbers? I believe it would likely be a lot cheaper that way.
Lol good luck. Some match right over, some you have to dig for, and some don't cross at all. It's all hit and miss from what I've seen, especially on the terminal side of things.
dolsen
Aug 19, 2022
2,078
1,898
KY
2022 Rapid Red 701A
Luckily I managed to find it pretty quickly. I’ll update the parts list once I have all of the terminals and everything
Jmeo
Jaime
Jan 1, 2023
194
228
Massachusetts
2023 Raptor, 2020 Shelby GT500
Firefighter
OK, you have my attention. I am excited to see if you can make this work. I would only want the headlights to adjust to ride height, not interested in CCD.
dolsen
Aug 19, 2022
2,078
1,898
KY
2022 Rapid Red 701A
It can absolutely be done, Jesse has already done it. In fact I think it’ll be “easy enough” but I can’t say for sure until I do it
J44snk
Feb 10, 2022
106
135
Calgary, AB
2022 502a Long Box PB F150, 2016 Kia Sorento
and editing some values in the VDM module, I was able to "dial it in" for an empty long bed F150 in Normal mode.
I'm curious, what did you change in regard to the Values in the VDM module?
9,041
16,384
Do you have CCD?
I basically edited the weight (in KG) of multiple categories based on the field mapping that one of those Forscan gurus laid out.
Yellow was a conversion to lbs just so I could get my head around the factory values.
The next column was the target weight after editing.
Last column was the substitute hex value representing the target weight.
J44snk
Feb 10, 2022
106
135
Calgary, AB
Do you have CCD?
Yes I have CCD, but everything is just stock at the moment.
Adjusting these values will change things for all drive modes, or just normal mode?
Do you know if this effects the headlight leveling?
9,041
16,384
Does not affect headlight leveling.
I will look for the thread that discusses what I did, why I did it, and what I was aiming for.
Just editing the VDM would be out of context.
Having said all that, if you want to experience just how much range of damping is actually available on the active suspension dampers (shocks), all you have to do is unplug one of them. Ford has it programmed that if there is a fault with any of the 4 corners, the system defaults to maximum damping.
It's kind of like having Fox 2.5 with DSC adjusters and purposely increasing the damping to max just to see what the available range actually is.
I think you will discover that from the factory Ford has the CCD damping map set very conservatively soft, similar to their analog factory dampers. Where I live, it's not my preference to be that soft.
By the way, the rear driver's side damper is the easiest to unplug to throw the fault. Just follow the wire to the connector.
Handle
Nov 11, 2021
173
214
Virginia
2015 Mustang
Do you have CCD?
Ok sounds interesting. I’ll give that a try unplugging rear driver shock and see what max feels like. No doubt Sport damping would be nice in Normal mode
9,041
16,384
That was EXACTLY my aim. And then some. :)
DBL R
Jarred
Oct 11, 2021
407
585
Washington
2021 F150 powerboost
PA
Any updates on driving with CCD unplugged?
9,041
16,384
Takes 2 minutes.
Try it.
It doesn't hurt anything.
Just pretend that you have analog adjustable shocks and you got out and dialed them all to firmest setting. Because unplugging one of these electric ones is doing just that!
