amschind
The 2.7/3.0 is a beast EXCEPT for the wet belt driven oil pump. It's like a pair of 30k# test chains tied together with one strand of baling wire: the weak link is REALLY weak.
Correct. Time will tell on these.Plenty of forum posts with 200k+ on the 2.7 motors. The wet belt is a minor concern. 5.0 has one too from my understanding and Ford built that to run with SC and 1k HP.
If it is concern grab ESP and drive it.Correct. Time will tell on these.
Same thoughts here. It’s a Kevlar belt, not worried about it. The failures in the EcoSports 1.0L are due to it having a weird tensioner system on the belt, and from my understanding that belt is just rubber. When that tensioner fails the nubs fling off the belt and clog the oil pump.If it is concern grab ESP and drive it.
I'm not at all worried about it. By time I get to high miles I'll be looking at something else. Maybe a 2.7 hybrid by then.
I've got a '23 501a with the 2.7. I had a '20 STX with the 5.0 before. I would definitely not roast you for having the 2.7. I haven't missed the 5.0. The 2.7 has gobs of power for daily driving. I DO miss the 5.0 sound though. Lol. The way I'm understanding it, the 5.0 is going to be standard on the Lariat but the 3.5 is only going to be an additional $290. For you, it may be time for a 3.5!Did anyone else notice that you can no longer get a Lariat with the 2.7L in the 2024 models? The base engine is now the Coyote.
I know I'm not the majority it seems, but when I got my "Lariat High" with Blue Cruise, Power Tailgate etc. I specifically wanted the 2.7--I wanted as many options as I could get, but with the 2.7L. I got roasted by a lot of people on the Facebook F-150 groups for wanting a "nice truck with a baby motor" or people would say "why would you spend that kinda money and not get the bigger motor, that's stupid!" But for me, it's exactly what I wanted--great power, great fuel economy (I only tow a race car to the track a dozen times a year), reliability and also some nice amenities. Heck, if I coulda gotten a Platinum with the 2.7 I would have, ha ha! Anyways, just thought I might check to see if anyone else had noticed that you can only get the 2.7L on XLTs and below now.
Kevlar isn't some kind of lifetime material. Drop a Kevlar plate or hang onto it past expiration and discard recommended. Unlike swapping plates in your carrier, swapping this wet belt is going to be a job and a half. May as well swap other shit while you're in there I'd imagine.Isn’t the belt made from Kevlar? That’s a pretty stout material.
I feel like my reason was watching too much TV when I was younger:I bought a 5.0 because I wanted a 5.0. no sane reason.
Something I didn't realize until after purchase but the traction motor in the Powerboost kinda fills the gap. It just freight trains effortlessly like a big tailwind.I'd pick the 5.0 in a perfect world. I never much preferred how turbos drive and it's just another wear item to worry about later.
Correct..... as I understand, both 5.0 and 2.7 have the wet belt.
Yes it’s considered lifetime and should last just as long as the timing chains is what I’ve heard. GM’s testing on the Duramax 3.0 shows it to be unnecessary to replace. GM originally set an interval of 150k, then sent out a service bulletin to change to 200k. What they found is even the 200k belts are coming back in perfect condition. So now GM has removed the maintenance requirement altogether since the life expectancy is 250-300k miles. Ford designed theirs to be life of engine from get-go.Correct.
Insofar as effort to 'swap', on the 2.7 R&R of the wet belt requires, among other things, removal of the RH timing chain; on the 5.0 it requires removal of both (referencing 2022 Service Manual).
Interesting to note that there's no specified service / replacement interval for this belt in the scheduled maintenance section of the Owner's Manual for either engine. So apparently Ford does consider it a 'lifetime' belt?
