2.4 Specifications for Transfer Switch
tottendan
Jan 14, 2023
2023 Lariat F150 Powerboost
I got a quote to install a 4-circuit manual generator transfer panel with 20 amp inlet. According to the electrician they asked if the 2.4 requires a lifted neutral for the powerboost to work? I am not an electrician and figured this awesome community could help.
78
4,802
4,961
It's subject to all of the same things the 7.2kW system is, and can be bypassed with a version of the dogbone which is easier because it's 120v parts.
Only the 2kW ICE specific unit features an unbonded ground.
Ask for a quote on a 30a generator interlock back feed setup as well. You can upgrade your 2.4 to a 7.2 for about $1k if you desire. The 2.4 can be sold for an unknown amount of $ as they are on ebay.
tottendan
tottendan
Jan 14, 2023
Wait - I can upgrade my 2.4 to the 7.2 in the back of the truck? I read many threads that eluded to that but never got confirmation.
dafish
Sep 11, 2023
257
151
Midwest US
22 F-150 PB KR SCREW, '18 Lariat SCREW
Mostly retired IT Pro - Cyber-IPT
I suggest wiring your house assuming so. Ford says you can't. We'll see.
I'm going to use mine as a guinee pig and then we'll know. Going to do some crude parallel generator tests first, and none of that till we get a little warmer.
78
4,802
4,961
Yes, you need part numbers...
MU5Z19A464L (formerly MU5Z19A464C) (on ebay for $170)
ML3Z14G649D (formerly ML3Z14G649B) (Make offer on used ebay parts ~$550est)
REDAG98
Red
Nov 2, 2023
47
Austin
2021 Ford F-150 Lariat FX4 PowerBoost
Regardless of whether you upgrade to the 7.2kW or not, I would ask the electrician to install a 30A inlet at a minimum. You might even ask about 50A as well. Either would be a significant upgrade from 20A and be much more future proof should you ever upgrade, buy a standalone genset, etc.
