Thanks... Someone posted it in the Mach-e forum last week. It's not caused by the widget because I never request a vehicle refresh. I leave that up to end users to do that manually. I think this is related to automations created by end-user with other integrations.@tonesto7,
Just posting this SSM as an FYI.
Personally, I've never had any issues with your Widget on 3 separate vehicles.
SSM 50804 - 2013-2023 Various Vehicles - 12 Volt Battery Drain When Using Third Party Phone Applications- Modems Activated Through FordPass Or LincolnWay
Some 2013-2023 Ford or Lincoln vehicles with modems activated through FordPass or LincolnWay may experience 12 volt battery drain symptoms when the customer uses non-Ford/Lincoln phone applications as an alternate channel to access vehicle commands such as door lock/unlock, remote start, vehicle location, etc. The battery drain may be caused by excessive calls for data through the vehicle network keeping it in an activated state. Recommend that the customer uninstall the app to ensure this is not contributing to battery symptoms experienced. Advise the customer that unaffiliated third-party app developers do not work directly with Ford to adhere to security, vehicle communication, and privacy requirements.
This is all data returned by Ford for your VIN. I try to make any and all data I find available to users, but I haven't really vetted all the info for the payloads.Good evening, joined the forum to ask this question:
In the Widget, under Advanced info>View Towing Payload Info...
Where do these values come from? I have Max Tow (14k lb) however this view states "12400 lbs".
Is this a 'live' value or just standard data from Ford?
Smart Hitch and Onboard scales are a feature I missed out on and really wish I had as I tow heavy, often.
Thanks for sharing I haven't received this notice yet.
Certainly and I am in no way implying that this is about your widget.Thanks for sharing I haven't received this notice yet.
I can assure everyone that I do not have access to anyone's ford account credentials. The widget doesn't share any data with myself or any other third parties all transactions are performed securely on the device it's running on.
Anthony:Thanks for sharing I haven't received this notice yet.
Based on your comment, just want to make sure you understand you do NOT have 14klb of towing.In the Widget, under Advanced info>View Towing Payload Info...
