And a different style rear axle, different leaf spring package, in some cases a thicker frame, bigger rear brakes, different rear bumper (the structure the hitch mounts two, not the decorative caps most call the bumper), and yes it is all done on the line...unless of course when they run out of parts and it's done 3 months later.The Max Trailer Tow Package consists of a 4-pin/7-pin wiring harness, Class IV receiver hitch, 3.55 electronically locking rear differential, 36-gallon fuel tank, auxiliary transmission and engine oil coolers, an integrated trailer brake controller, and an upgraded front stabilizer bar. Smaller fuel tank and taller differential if it is a Powerboost. All is built into your vehicle as it progresses down the assembly line.
Only things in the Order Guide that are under the "Dealer Installed Options" section for each trim are actually left for the dealer. Everything else is off the line.I would assume as with the bed liners, that options like the Max Trailer tow package get installed after the build date.
"In some cases a thicker frame" - do you know when? I've been trying to figure out why my truck weighs 1,000 lbs more than an almost identical truck where the only difference is other truck has a 5.0 (mine has 3.5 EcoBoost) and the other truck does not have Max Trailer Tow. What the heck weighs almost 1,000 lbs??? I found one source that suggested a thicker frame comes with Max Trailer Tow, but nothing else to verify that.And a different style rear axle, different leaf spring package, in some cases a thicker frame, bigger rear brakes, different rear bumper (the structure the hitch mounts two, not the decorative caps most call the bumper), and yes it is all done on the line...unless of course when they run out of parts and it's done 3 months later.
I have never seen any suggestion that there is a different frame used with Max Tow. Any extra information on this?And a different style rear axle, different leaf spring package, in some cases a thicker frame, bigger rear brakes, different rear bumper (the structure the hitch mounts two, not the decorative caps most call the bumper), and yes it is all done on the line...unless of course when they run out of parts and it's done 3 months later.
According to the 2022 F150 eSourcebook the several different frame side-rail section dimensions (including thickness), section modulus, and yields strengths used in the F150 are associated with different cab, wheelbase, 4x2 vs 4x4, and payload package configurations.... in some cases a thicker frame ....
Did you actually weight your truck, or are you doing math based on GVWR and payload?I've been trying to figure out why my truck weighs 1,000 lbs more than an almost identical truck
Both, kind of. I weighed mine - it weighed 5,643 lb with roughly 220 lb of passengers & cargo. Which works out very close to the max stated payload of 1,750 (GVWR is 7,150).Did you actually weight your truck, or are you doing math based on GVWR and payload?
What is your GVWR and payload rating on the sticker in your door jamb? For you to be 1,000 lbs heavier than another truck that appears to be the same build, they would have to have like 2,500 lbs of payload, or you have like 400 lbs. If the former, you were probably comparing to a HDPP truck and didn't notice the GVWR differences.
Ok that explains it.dealership had one they said
yes, like most salespeople, they don't know jack and commonly provide misinformation.......... the dealership had one they said had max payload of just over 2,700 lbs. .... It also did not have heavy duty payload package (it was an XLT sport with 302a, so couldn't have) and GVWR was also 7,150.
Am I missing something??
There's no way a 302A with those options has a 2,700 lbs payload. That's pretty much exactly my truck but mine has 3.5L, 360 cameras, 20's, scales, max tow, pwr pedals and fold flat storage.The other truck I did not weigh - but the dealership had one they said had max payload of just over 2,700 lbs. It was the 5.0L engine and it didn't have the max trailer tow package. It also did not have heavy duty payload package (it was an XLT sport with 302a, so couldn't have) and GVWR was also 7,150.
They are both super crew 6.5 ft box and 4x4. Both have FX4, trailer tow mirrors, sport package, and tailgate step. The only option differences are dealer's truck has the work surface (mine doesn't) and the 18" sport pkg wheels, and mine has max trailer tow, B&O sound system, power adjustable pedals, onboard scale, and 20s.
