TheCleaner
@Sky111
May I ask what device you are using for Bluetooth monitoring of the voltage?
OBDLink MX+
@Sky111
You can make your own for ~$500 w/ quality cells. The BMS allows you to set all sorts of parameters. You can't just swap in a LFP battery in trucks that have the aux battery as they're different chemistries and only isolate during start.one more comment: I abandoned the crazy idea of getting lithium car battery. it is not only $1200 US vs CAD$300 , but the main concern is Ford BMS that will likely to damage the lithium battery. Yes Antigravity batteries do come with their own BMS, but I am not brave (or crazy) enough to yank out factory BMS. And Forscan does not let you to customize BMS settings beyond type of the battery (AGM or flood), and % it will charge...
David, this is EXACTLY what I need to do! Charge current drops off to a 1-amp float charge at 80% SOC. I need to get it higher for when I charge Battery Stihl chainsaws in the woods. I haven't measured the SOC consumption yet when doing so, but I estimate about a 40% SOC drop after charging at 30 amps DC draw. I could really use that extra 15% charge.On another note. I went into the BCM with forscan and changed the BATTERY TARGET STATE OF CHARGE TO 95%. Monitoring the charging I get conventional charging to 95%. The system now floats the battery SOC at 95%. Since doing this the truck has not gone into deep sleep. No issues with anything else other than the auto start stop kicks in more often.
Hopefully everything I typed makes sense.
Forscan change; BCM, 726-08-02 (xxxx xx05 00) = 80% Target State of Charge
BCM, 726-08-02 (xxxx xx05 F0) = 95% Target State of Charge
