It's simple math, yes the ram charger with its 130kW generation can both tow a trailer and charge its battery simultaneously. Here's the interesting part since the math is easy to do. The tesla semi averages 1.6kWh/m (in pepsico's use case), the ram charger's generator can provide the tesla semi 81 miles of range / per hour. What wasn't provided regarding the semi is what its usage per given speed. That's just an average so what the math doesn't tell us is that it can run it at say 70mph which may use more power than the average.The Lightning is fine, but if you tow, its nearly worthless. I have no idea how the Ramcharger may or may not fix this but if you can continually tow hundreds of miles so long as there is fuel in the tank.... definitely better than Lightning. Now, perhaps if the battery is depleted, even with fuel in the tank, maybe it won't have enough power to keep towing full loads??
What we do know however is that the RC uses a common vehicle V6 NA engine. Car engines are designed to be decently efficient across a broad RPM. A smaller purpose built engine tailored to run at peak efficiency for constant RPM would be a better fit both literally and figuratively. They're just using an engine they have at hand already for the project to get it out the door.
Where the RC concept diverges from reality is that the power generator is ~500lbs dead weight when not needed. The battery with 140miles or more of range is also dead weight if not needed. The average daily mileage is somewhere around 40 miles. In the next 4 years chargers will have significantly increased in volume -- there should be nearly 3x as many within 5 years time. The more ubiquitous the charging situation, the less sense having both a large battery and power unit onboard makes. That use case is going to make for a horrible ownership as no engine likes to sit for months at a time, nor does ethanol containing gasoline. Perhaps we'll see this evolve as they get their test articles on the road providing better clarity to what the realistic use / needs are.
