Golf Cart Wizard
- Jamie
- Sep 3, 2023
- 1
- 23
- 19
- Southwest Florida
- 2023 F150 STX Supercab 2.7
- Golf Cart Technician
The road damage part is probably the biggest thing people are missing IMO. There is no escaping the 4th power law. One Silverado EV does as much pavement damage as SIX regular F-150s. And who’s going to end up paying for all the road repairs?EV FS Trucks & SUVs don't really work for most families as they are do it all vehicles for most families. EV trucks, like the Silverado with a 205 kwh pack end up needing environmentally catastrophic battery capacity that doesn't really get used 95% of the time, but then when you need it, it's still not enough to tow or road trip. You have weight, road damage, danger to other road users, long charge times, etc.
Electric motors are very good at a few things, they are GREAT at propulsion and efficient use of their energy. They are also luxurious as heck, smooth and quiet with amazing torque.
Batteries however are not good at dense energy storage. For example, a Model 3 battery pack at 75 kwh holds the equivalent energy of only 2.2 gallons of gasoline! It's just that the electric propulsion system is very efficient at using this energy and has the advantage that you don't need to 'leave a couple of gallons in the tank so you don't pick up air'.
You get the point right with the batteries being the problem. I’ve been working on golf carts my whole life (which come in both ICE or EV) and the reality is electric propulsion is superior to ICE in pretty much every metric, especially reliability and repair costs (except when manufactures make their EVs unnecessarily complicated to seem “futuristic” and “high tech”, but that’s another topic). The problem arises with how the electricity is supplied as you pointed out. The difference on golf carts is the energy requirement is low enough you can get away with stringing together a few lead acid batteries, or using a small enough lithium pack to where vehicle weight is equal to the ICE equivalent.
The size of battery required for an electric automobile is ultimately the problem with current technology, that’s why the idea of a BEV truck with an onboard generator is appealing. Even more so if the generator is designed to be modular so should it fail in 15 years it could be swapped out for newer better technology. This is probably wishful thinking though, it seems manufacturers are heading for total integration requiring original replacement parts plus programming to function.
