Locking Fuel Door\Cap to Keep High $$$ Gas Thieves Out!!
imnuts
Mar 1, 2021
1,501
1,568
Dirty Jerz
'21 502A Powerboost 4×4
Facilities Engineer
Powerboost trucks have a latch on the fuel door.
PungoteagueDave
593
791
33435
Which release button are you referring to? I can basically press on the fuel door and open it even when the car is locked, unlike other vehicles where this door is locked if the car is locked. I am referring of course to newer vehicles where there is no cap on the fuel tank, just the door (whatever this newer fueling system is called).
There's a release button on the lower left dashboard that electronically opens the fuel door on PowerBoosts. You cannot open the PowerBoost fuel door manually or from the outside when the vehicle is locked - EXCEPT using the emergency release cable, which is hidden in the rear wheel well. There is a seal around the fuel door that uses a vacuum to control volatile gasses, so there is a slight delay after pushing the dash button for the door to release. I prefer my 1958 VW beetle deluxe format, which has no fuel gauge, just a lever on the floor to switch to reserve for 30 added mile when the car sputters, and a filler under the front bonnet. Life was simpler before charcoal canisters, EPA regs, seat belts.
sbi
Sep 4, 2020
83
1,247
846
Upstate SC
2021 F-150 5.0L Lariat FX4 Space White SCREW
There's a release button on the lower left dashboard that electronically opens the fuel door on PowerBoosts. You cannot open the PowerBoost fuel door manually or from the outside when the vehicle is locked - EXCEPT using the emergency release cable, which is hidden in the rear wheel well. There is a seal around the fuel door that uses a vacuum to control volatile gasses, so there is a slight delay after pushing the dah button for the door to release. I prefer my 1958 VW beetle deluxe format, which has no fuel gauge, just a lever on the floor to switch to reserve for 30 added mile when the car sputters, and a filler under the front bonnet. Life was simpler before charcoal canisters, EPA regs, seat belts.
I remember those beetles, they were super great and reliable cars :)
I am curious, why would there be a different fuel door mechanism between F-150 models? Why does the PB has a button inside the truck and in "conventional" engines the fuel filler is open for all?
imnuts
Mar 1, 2021
1,501
1,568
Dirty Jerz
Facilities Engineer
It's due to regulations applicable to hybrid vehicles. It needs to have a pressurized tank, non-hybrid models do not.
DBL R
Jarred
Oct 11, 2021
407
585
Washington
2021 F150 powerboost
PA
the fuel release button on the PB unlocks the hatch/door to the fuel reservoir and depressurizes the system. I’m not sure if this functions in the same way on other models. But my fuel door isn’t able to be opened without that button being hit. I’m a job 2 ‘21.
Buyer2021
Feb 9, 2021
1,660
2,872
TX
retired!
sbi
Sep 4, 2020
83
1,247
846
Upstate SC
I understand, but in my 5.0L Lariat there is no button to release the hatch, you just press the hatch to release it and it can be done even if the truck is locked.
1,997
Ford should be able to have the alarm go off when the fuel sender value changes from a set threshold just like they have for the alarm getting triggered when an attached trailer pigtail is disconnected when the truck is off. They could even do the same for the O2 sensors to protect the cats.
The reality though is that we shouldn't have to be driving around like it's Mad Max, protecting your personal property and your own safety begins at a place that I can't talk about here. Many of the scumbags stealing gas and catalytic converters should probably be in some kind of institution or another and not getting unleashed on a polite society.
The capless filler necks can be defeated whether the gas is successfully siphoned or not, the result is a failure code from the evaporative system and a $800ish repair bill. Which is total bullshit considering a failed fuel cap seal costs $5 to swap and certain vehicles have been having recurrent failures with their capless fillers, meaning that some people have had to pay for having them replaced multiple times during their ownership experience.
Jus Cruisin
Feb 13, 2021
879
926
Metro Detroit
2023 GMC Sierra Denali Ultimate 4X4 - 6.2l
Very retired
I've had capless vehicles since 2008. Both Ford and Ram. I've never had issues.
juicepower
Dan
Jun 2, 2021
51
41
atlanta ga
2021 F150 XL STX 4x4 VELOCITY BLUE
Integration Engineer
SumGuy
Jul 21, 2021
483
382
F150 (perpetually on order)
Drugs
A lot of them are no longer being sold to scrap yards. There have been enough stolen from certain vehicle models that they are essentially creating their own replacement market by selling them to disreputable repair shops, who use them to repair the vehicles they were stolen from. There is also a newly emerging trend where their contents are being used to produce drugs.
I agree with your point though, that there is more that could be done to make the market less appealing.
Without a title, the cats cannot be sold to the repair shops either then.
as for melting down the contents, few will go that far, but definitely some will.
jz777
Jerry
Oct 3, 2021
168
184
NE Pennsylvania
2022 F150 Lariat, 2020 BMW M240i Convertible
I think they would just grind them off.
I don’t think most thieves are that intelligent. lol
But, also, we need to have scrapyards that on the up and up to check for etched converters, require ID on sales, and report suspicious sales. Unfortunately, some of the scrap dealers are as shady as the thieves.
Sean80
Nov 12, 2021
48
31
Peterborough, On
2022 f150 Tremor (on order)
I don't know if you've ever tried but it's absolutely impossible to siphon anything out of your tank due to the baffles in the tank where the filler neck enters. I tried when I needed gas for a generator during a hurricane last year!
The easiest why to steal gas is to punch a hole in the plastic tank under the truck and fill cans, real easy on lifted trucks. For protection from this I put a 1/4" aluminum skid plate under the tank end to end and rolled up on the sides it now protects the entire 36 gallon tank. Or a $162.00 of fuel at 4.50!
So if they have a drill, won't they just drill through the 1/4 aluminum? Sorry, but I don't think that's going to help anything.
