@Heavishot -4 fill-ups so far computer is .1 - .75 better mileage than reality.
Yeah, I tracked the first few tanks on our Outback when we got it ten years ago. I don't think I've ever rechecked it since.I don't even bother to check. I stopped hand calculating years ago. They are knick named LOM for a reason. I do see it all the time because that's what I have in the center of the IP. I use it as a gauge of what the engine is doing. Any strange differences will alert me to a potential problem.
I'm on tank 5. Through 4 tanks the difference for me was +.36 MPG higher on the truck's numbers. Close enough that I'm not going to bother with hand calcs any longer.I kept up on 5 different fill ups. I wrote down what the truck said I got, gallons used and miles driven. I then averaged out all the data collected over the 5 fill ups.
1. Total miles driven= 1,037.7
2. Total gallons purchased=53.02
3. Average MPGs from 5 events estimated by truck=20.74
4. Average MPGs calculated manually and calculator= 20.06
Difference from manual calculations and truck calculations= +0.68 MPGs higher with the truck numbers.
The the truck system was just a hair over 1/2 MPG higher than actual manual calculations. I did have one fill up that was off more than the other 4 by twice what the others were. You throw that one out and only use the other 4 the difference is even less than +0.68. It would have been +0.3
Think I am just fine with relaying on the truck numbers!
I also did this on my 2018 Eco Boost and got very similar numbers.
That's good to know for sure. I've seen a few videos out there and some say the gauge reads 1-2 mpg high and some say they read low. I'm curious how the measurement is actually calculated. I've also read on here that the distance to empty is off up to 5 gallons. Pretty crazy seeing as some see over 600 miles on a take.15,000 miles, +/- 1 mpg
more important is DTE, which is accurate to about half a gallon … when the gauge shows "1" mile to empty, you've got maybe half a gallon in the tank Call or a 10 mile reserve or in other words, the most I've ever poured in is just over 30 gallons.
