High Capacity Transmission Pan
joejamesatou
Joe
Jun 1, 2021
33
90
Ford F-150
Employed!
Does anyone know if the regular 10 speed high capacity pans fit our transmission? Anyone added a transmission cooler?
lrb_35128
Larry
Feb 4, 2024
61
San Antonio Metro Area
2024 F-150 King Ranch
If I'm not mistaken, the 10-speed transmission has a cooler built into it, employing coolant from the front radiator. Thus, the easiest solution would be a larger core radiator to increase both coolant volume and surface area for heat dissipation.
(I'll let the masses pile on to correct my inaccuracy...) ;)
Samson16
Kyle
Mar 24, 2023
2,123
1,964
Orlando, FL.
'22 F-150 XLT Powerboost Super Crew 4x4
Aviation systems
Oh there are considerable rabbit holes…I mean threads regarding transmission cooling.
Boen
andy
Nov 15, 2022
129
washington st
22 F-150 Platinum
The 10 speed needs to be hot to operate properly and if you lower temp will effect operation and emissions
Gros Ventre
Nov 13, 2021
1,650
1,133
Western Wyoming
Powerboost
Recall that the PowerBoost transmission is a somewhat longer body because of the electric motor/alternator on the front. Don't know for sure if this applies but the transmission filter is not the same size as the non-hybrid transmission. They cannot be interchanged.
amschind
Apr 22, 2022
757
666
'21 F150 SCrew 4x4 Powerboost
Physician
I want some clarification on this, and don;t know where to find it. My assumption based upon very limited information is that the PB ICE and transmission are off the shelf parts and could be bolted together to form the powertrain for any other 3.5 EB F150. I.e. the electric module is built to be a fully optional add on between those two otherwise normal units. I would love solid information on this, as I have very little to go on.
joejamesatou
Joe
Jun 1, 2021
33
90
Ford F-150
Employed!
I wish! It's a unique 10R80-MHT. Just different enough that it's a unique pan. Trying to find a high capacity pan is all.
4,591
4,711
L1MZ7A194A
Ford F-150 High Capacity Transmission Pan 1711663303571-ut
Ford F-150 High Capacity Transmission Pan 1711663342810-ml
4,591
4,711
Another generic pan
Ford F-150 High Capacity Transmission Pan 1711663599876-l
Calson
Jul 16, 2022
724
349
Monterey CA
2022 F-150
I go with the adage that if it ain't broke don't fix it. Decades ago a transmission cooler was important for towing. With your transmission if the ATF exceeds 300 degrees when towing then definitely add or upgrade the cooling. If it runs at 250 degrees then forget about it.
Gros Ventre
Nov 13, 2021
1,650
1,133
Western Wyoming
Powerboost
What I can say definitively is that the filter for the PB transmission is not the same as the non-PB transmission and cannot be substituted into the non-PB transmission. As to specifically the difference, length, etc, I do not know.
4,591
4,711
MHT pan has lines that run up to front top of pan
Ford F-150 High Capacity Transmission Pan 1711671979546-um
Samson16
Kyle
Mar 24, 2023
2,123
1,964
Orlando, FL.
Aviation systems
The transmission is cooled solely by engine coolant. When the turbos dump heat into the coolant it becomes less capable of cooling the transmission. More transmission fluid just delays the inevitable. The Raptor has an external air/fluid cooler separate from the engine I think. PB uses the space unfortunately.
I could be wrong lol.
ReverendQ
Kevin
Mar 26, 2023
188
200
SoCal
Website
www.linkedin.com
2023 F150 XLT PowerBoost 302A Avalanche BAP
Has anybody considered or implemented something like https://www.summitracing.com/parts/der-13262?rrec=true I.e. mounted on the frame away from exhaust, etc. heat?
I haven’t done a thermal analysis since I am not sure that we should be cooling the transmission anyway. But I do tow a little and even in SoCal cool temperatures have seen some high transmission temperatures.
