Oxford_Powerboost
Austin
Jul 16, 2021
832
1,079
Northern Virginia
2023 F150 Lariat 5.0
I pull an 18’ tandem wheel trailer with a UTV and ATV. Did a 5,800 mile trip in June and a 3,500 mile trip in late September. Average mileage was a little over 10 mpg both times. Plenty of power in the mountains but mileage really goes down. I don‘t seem to fill up as often as you though, got close to empty a few times With 30+ gallon fill ups.
Powerboost has a 30.6 gallon tank. You were literally on fumes ?
9,040
16,384
I'm pretty sure if you do a couple of clicks past the first shutoff you are more than a gallon and likely close to two over the published fuel tank size.
That's not true for every vehicle by every manufacturer, but Ford trucks often aren't nearly as empty as you might think when you pump the published quantity into it at the pump.
And considerable wiggle room considering the fuel gauge and "Miles To Empty" readings. Even the Ford literature discloses that there's still fuel when it indicates there isn't.
Having said all that, I personally don't like to run those in-tank fuel pump vehicles low before fueling. That pump often is relying on the fuel it is submerged in as its coolant. :)
pkinneb
Paul
Jul 25, 2021
781
1,128
Zimmerman MN
2003 & 2018 MX5's, 2021 F150 PB Platinum
I wasn’t trying to get that low. When the next pump is 30 miles away you can burn through 3 gallons fairly quickly pulling a trailer.
Been there! My 97 light duty F250 got about 7 mpg towing our 5th wheel I had to start looking for gas at about 180 miles. The second time I ran out of gas we got a MH lol
CaptainAmericaRob
Rob
Aug 27, 2021
208
255
2021 F-150 Lariat FX4 PB
Machine Designer - Ford Motor Co.
correct, I was told by a Calibration Engineer, that Ford vehicles are calculated ZERO with 1 gallon in the tank, plus there's between 1/2 and 1 gallon of fuel in the lines themselves.
pkinneb
Paul
Jul 25, 2021
781
1,128
Zimmerman MN
True enough but at 7 to 10 mpg when towing that isn't much :)
9,040
16,384
I concur!
When you are running 10mpg (or less), having an extra gallon ain't saying much!
I remember in my youth that our vans and trucks got 8-10 mpg ALL the time. It's amazing that we thought filling up so often was OK. Lol
rodsterinfl
Rod
Oct 8, 2021
Saint Augustine, FL
2017 Ford F150 Platinum 701A
Educator
Wow! I just ordered a 2022 hybrid. I have a 2017 3.5 Platinum and tow a 25' Airstream. I use Fuelly and average 11 mpg (rounded) towing. I have towed in FL, GA, SC, NC, VA, W VA, TN, KY, OH getting that average. The worst I ever got was 8.23 MPG in the mountains driving around in W VA. This is the same mileage avg. I got on the 2015 Lariat 3.5 and the 2009 4.6LHO. I calculate at the pump and ignore the computer.I have a ProPride hitch and learned to get up to speed quickly with Ecoboosts rather than move laggardly up to speed for better mileage.
SQUANTO
T
Oct 21, 2021
2022 Lariat on order
I would say your load is considerably more aerodynamic than the OP's TT, hence the better mileage.
SQUANTO
T
Oct 21, 2021
@machWhat is your loaded tongue weight?
Gros Ventre
Nov 13, 2021
1,650
1,132
Western Wyoming
Powerboost
On the turbo's: recognize that the engine can be on the turbo's and the dash gauge shows zero. Say the engine is at light to medium load and calling for something like 5" of vacuum. The turbo's will likely be running (maybe just barely, but it will be enough to call for enrichment), so watch the engine & rpm.
Gas tank level: the in tank fuel pump has a bucket it's in, so it will be cooled even when the tank level drops below the bucket's top. But in the end I like 1/4 tank as a minimum because with the long thin tank if you go up or down a steep incline the gas can slosh away. If your pump goes dry, even for just a second or two, its life is shortened. In my experience, if it loses suction it will fail completely within 10,000 miles.
