L1 and L2 desperately want to return on the neutral. If a neutral is some how disconnected, the ground is 'insurance' of sorts as now L1 and L2 want to get to the ground (when neutral is bonded). Without the neutral bond, a device whose neutral gets loose could end up making the ground live giving you touch potential electrocution, or in a wet area, step potential.UPDATE… I reconnected the ground at the plug and removed the ground wire from the neutral bus in the panel. The system is working. When the truth is on it works which I expected it too and it also works with the truck off, running on batteries. Is there a safety concern with this? From what I can tell there’s no neutral/ground bond when I’m running off the batteries. My magnum inverter doesn’t bond from what I read so … ??
Treating the truck and generator as utility is the safer option. Both the truck and generator are neutral bonded -- nearly non-existent chance of electrocution when they're operating. The truck's ground is also bonded to the frame which also happens to be your 12v dc negative. Nearly zero risk of shock from it as the pixies it generates are wanting to return to it, combined with the fact that it's also GFCI, any current that comes back on the ground from any of the plugs instantly trips the breaker. Great as a stand alone generator, no utility in a properly wired structure where wet areas will already be on their own GFI breakers.
