Porpoise Hork
Bret
Aug 27, 2022
1,013
1,045
Houston
IT
Are you spending time idling? Is that when the fumes come in? If it happens while driving it would seem like and exhaust leak
Happens for both and no exhaust leaks. It's sucking in fumes from the outside. The truck is not a diesel and get a STRONG smell from those especially when sitting at a light near them as well as driving behind them.
Big Cam
Nick
Oct 10, 2022
453
414
North Dakota
2022 Ford F150 Tremor 402a
Support Engineer
I just thought I'd share, these were taken in my garage so some light but mostly indirect.
Below is stock which I believe was 10% (not positive), the top is the 60% I set it at. Big improvement. I may go brighter, but I wanted to start small.
Ford F-150 2021+ F-150 FORScan List / Database / Spreadsheet ? PhotoCollage_1668627389695
Porpoise Hork
Bret
Aug 27, 2022
1,013
1,045
Houston
IT
I took mine to 100% right out of the gate. Dang lights are ridiculously bright now... :ROFLMAO:
GDN
Greg
Feb 15, 2022
336
311
Dallas, TX
Lightning -Lariat ER, Model 3
IT
That is a big difference, I can assure the Lightning isn't adjusting like that. Not totally sure I expected it to, but was hopeful.
Imo
Melchior
Nov 13, 2022
Poland
F-150 2021 3.5l ecoboost
To switch them at 60% I just need to type "3C" in
BCM726-38-01xxxx**xxxx--
Where the "**" is? I'm new to forscan and don't know what "3c hex" and "4c" hex means
Buyer2021
Feb 9, 2021
1,654
2,856
TX
retired!
Ford F-150 2021+ F-150 FORScan List / Database / Spreadsheet ? 1668692049340
Just to confirm .... vehicles delivered OE with the value "0" in the indicated address / position do not have Fake Engine Noise, is that correct?
(e.g. my 2022 3.5EB Lariat 500A without B&O)
Big Cam
Nick
Oct 10, 2022
453
414
North Dakota
Support Engineer
That is my understanding. I believe it is only the B&O systems that do it.
Big Cam
Nick
Oct 10, 2022
453
414
North Dakota
Support Engineer
Correct, when doing Forscan stuff, find the line 726-38-01, then there will be 3 boxes with 4 numbers/letters in each, find the location where the 2 ** are in the line and replace whatever is in that position with the new value.
For example it would look like this (my numbers are fake)
726-38-01 5555 7777 2222 (Factory)
726-38-01 5555 3c77 2222 (60%)
  • Like
Reactions: Imo
Zyvin
683
878
SC
2021 F150 Crew, FX4, Lariat
Has anyone found and verified working way to disable the HVAC switching to fresh air when it's cold out yet? I have tried the Forscan codes for HVAC posted up and no such luck. It still flips at random to fresh air if the air temp is set any warmer than the outside temp and fills the cab with exhaust fumes. Even with an activated carbon filter it's bad. Not as bad as the Ranger was but still enough to cause my asthmatic kid issues.
I haven't found a way to do this yet either. The earlier thread's changes seem to work only when the A/C is on. Now when my A/C is on, my recirc stays engaged most of the time, but when I just set the temp without A/C on the recirc times out in 5 min exactly, every time. You could always turn the A/C on an just adjust the temp higher and see how that works as a temp solution.
Porpoise Hork
Bret
Aug 27, 2022
1,013
1,045
Houston
IT
Interesting, I'll have to give that a try.
It will stay on recirc if the set temp is lower than ambient but if it's reversed, it will flip to fresh air at will.
Nightshade
AJ
Sep 4, 2021
471
233
Alberta, Canada
'22 Ford F-150 Lariat | '22 Ford F-350 S/D Tremor
Firefighter Superintendent
Still at 100% too when I first posted it; zero flickering so far (knock on wood) and been so many months. —I love the brightness haha.
Porpoise Hork
Bret
Aug 27, 2022
1,013
1,045
Houston
IT
It may have only been on the trucks within the scope of the current recall for flickering that would have it happen.
Nightshade
AJ
Sep 4, 2021
471
233
Alberta, Canada
Might be! I’m curious to see what the fix is for those, all I heard is it’s a software update and one thing I’m a little confused (didn’t get a chance to read the entire thing) but is the recall for the ‘22s or includes the ‘21s too? I haven’t seen anyone that has a ‘21 that got the recall.. yet.
Buyer2021
Feb 9, 2021
1,654
2,856
TX
retired!
Per the Ford filing with NHTSA, Part 573 Safety Recall Report 22V-686, the affected F150s are 2022 model year:
Production Dates : MAR 11, 2022 - JUL 23, 2022
TJSparky
Oct 18, 2021
501
439
WA
Mine flickered at 100%, 70% was the sweet spot for my truck with no fog DRL flicker
