Heathen
If I’m understanding, I need to edit all 7 module addresses for global to work?If, in addition to the global windows FORScan edits to door modules and BCM, you also do the "Optional" edit to the APIM mentioned in the notes column, you'll find a new line in the "Settings">"Vehicle" menu list labeled "Windows". Maybe not necessary but I did an APIM reset after this edit before exiting FORScan.
Pick that "Windows" item and there you can toggle 'remote open off/on' and 'remote close off/on'' separately.
Both were 'off' by default when I added that option, toggled 'em 'on' and that did the trick.
Hope that helps, please follow-up.
