Every 4000 miles on my 2021 PB F150. Mobile1 5w30 spec.With constant on off of the engine just keep in mind of fuel contamination of the oil. With the 21 PB changed oil at 5k miles but the approximate break down was 1000 miles electric, 4000 ICE miles.
As for oil / filter. Any oil and filter meeting the FORD specs.
After watching a few Youtube videos and reading a few oil test reports, without being easily influenced, I decided to use Amsoil oil and filter. Canton filter was a stretch for me but I did look at them and they look solid. Is the top lid on Canton filters easy to remove given the placement of PowerBoost filter? Right now I will aim for 5000miles between changes but I will also monitor the oil life meter and change earlier if necessary.I'm partial to AmsOil. But look around and pick the one you think is highest quality oil. After all, there is synthetic oil, and then there is synthetic oil. As to filters, I use Canton Racing Products 8µ filter with one of their 1µ filters set up as a bypass filter. In any event look around at the filtration capability and pick the lowest you can find. Stick with that.
Yes, I have no problem getting it off or back on. I use their short filter. There's likely room for the longer one, I was just unsure of that early on and ordered the short one. The particular location leaves much to be desired by the Ford engineer that set that up............ :-( , but that's life in the big city.After watching a few Youtube videos and reading a few oil test reports, without being easily influenced, I decided to use Amsoil oil and filter. Canton filter was a stretch for me but I did look at them and they look solid. Is the top lid on Canton filters easy to remove given the placement of PowerBoost filter? Right now I will aim for 5000miles between changes but I will also monitor the oil life meter and change earlier if necessary.
I think that these are two really important questions:Cannot go by miles driven as a vehicle driven primarily on the freeway at 65 mph and after 5,000 miles has been in operation for 80 hours or less is not the same as a taxi in NYC that after 5000 miles of driving has been operating for 250 hours. Guess which vehicle's motor oil has the most in need of changing.
My first car was a 1952 Willys and in those days a vehicle with more than 100,000 miles on the original engine was considered to be very special. And the American engines were geared to run at 2,000 rpms at freeway speeds. It is not unusual now to have car engines go for more than 300,000 miles without any major repairs and the difference is in the materials and the lubricants being used.
