What shock with lowering shackles?
Stealth88
Jan 12, 2023
123
151
2021 F150 XLT 302a
Aerospace
I have a 21 xlt crew 2wd 5.0 and lowered with Ford Performance 1.5” lowering shackles. I had noticed the rear ride poorly before the shackles and now really notice the bad ride.
What shocks would you use with lowering shackles? Don’t think the stock ones are up to the task any longer at 28,xxx miles.
Ford F-150 What shock with lowering shackles? IMG_2955
SnowMan
JD
May 8, 2022
TBA, Florida
2022 F150 XL 4x4 5.0 RCSB
engineering manager
I use the 2WD Bilstein B6 4600 33-253213 with 2" lowering shackles (and 4WD blocks removed).
Davidwnuc
Mar 13, 2022
259
223
Mississippi
On order ‘22 RCSB.
The best way to do it is take some measurements. If you search online you will find several how to’s associated with measuring for shocks. I purchased shocks based on a vendor’s recommendation and didn’t get the best results. So i measured and found out the shock wasn’t quite right for my setup. What’s recommended above may be perfect…just measure to make sure.
My $.02.
Stealth88
Stealth88
Jan 12, 2023
123
151
2021 F150 XLT 302a
Aerospace
I would up getting the Bilstein 4600 for 2wd since I’m 2wd but I may get some shock extensions just to keep it in a somewhat stock setting. I’ll eventually get the fronts replaced also since they ride so well.
