oneinch
- Apr 17, 2022
- 30
- 473
- 462
- Philly area
- 2022 F150 Powerboost, 2022 Maverick Lariat Lux
I installed 1.5" lowering shakes on my CCD equipped truck. All appears to be just fine, but I have reason to wonder now. I may have to reinstall the factory shackles to take some measurements I didn't know I might need.
Anyhow, as I said all appeared fine until one day I looked at my not needed, never used, likely never will use onboard scales. Sitting empty my truck is over loaded and in the red. I'm thinking the suspension/ride height sensors are sensing the bed being lower thinking there is weight in the truck. Your thoughts?
Before I go and reverse my lowering job I figure I can test with a couple of floor jacks. I think I can start jacking up the frame from the rear to "lift" the suspension and check the onboard scales again. If the scale weight goes down then I'll know the sensors need to be adjusted somehow someway.
