Rjp413
I am looking to lower the rear of my 22 XL STX 2WD as much as possible without cutting the bed support and i have a set of shackles that I planned on installing (Maxtrac 413710). Here is the link to these: https://maxtracstore.com/2021-2022-ford-f-150-2wd-4wd-1-rear-lowering-shackles-maxtrac-413710/
In viewing some older posts I've seen on this topic, I've also discovered these, which are the same model number but with "prs" at the beginning: https://www.suspensionsuperstore.co...-4wd-1-5-2-rear-lowering-shackles-prs-413710/
At first I thought these to be basically identical, but the description of the 413710 says it provides 1.25" of drop, while the prs-413710 claims 1.5-2" and "the lowest amount of drop without cutting the bed."
Can anyone confirm that the prs model is indeed going to be a tad bit lower on my truck or do both of these shackles provide the same drop for 21+ trucks? I find it hard to believe they might actually be different by .25-.5" and if id even be able to tell, so wanted to see if anyone knew for certain or had actual specs from their own experience. Trying to decide if I actually should go ahead and buy the other ones or just use the ones I have. Any pics with either of shackles on your 21+ f150 would be greatly appreciated. Also, if you have any other recommendations or links to other shackles that you know are the absolute lowest out there without modifying bed support, I'd appreciate that as well. Thanks everyone
