BM3
I went with the OEM Ford Exhaust pipe so I wouldn't have any issuesCan you let me know what exhaust you get installed?
Thanks
ML3Z-5202-H / ML3Z-5202-J
Thanks
Sorry I don't have a picture. Currently I'm using the stock muffler, he had to fabricate a custom Y pipe for the duals to fit because our stock muffler (5.0L) has one inlet and one outlet. The 3.5 Tremor muffler has the correct configuration for duals one inlet and two outlets. Just on the fence right now still very quiet with the new dual setup, I would like to change our stock muffler to a Borla or Vibrant just unsure which direction to go.BM3, what muffler are you using to connect those tailpipes? Is there any chance that you have a photo of them connected to the muffler? I have been waiting for the Borla Tremor tailpipes since July, but they are still not available. If the Ford pipes will fit my Borla muffler, then this looks like my solution.
Well I would be happy to record my Borla system for your listening pleasure. Just for grins I was thinking on using one of my guitar amps to really bring up the sound...Sorry I don't have a picture. Currently I'm using the stock muffler, he had to fabricate a custom Y pipe for the duals to fit because our stock muffler (5.0L) has one inlet and one outlet. The 3.5 Tremor muffler has the correct configuration for duals one inlet and two outlets. Just on the fence right now still very quiet with the new dual setup, I would like to change our stock muffler to a Borla or Vibrant just unsure which direction to go.
Where did you buy all your parts from? I found the end caps and top step pad second hand but it doesn’t have mounting brackets
I went the raptor bumper route, think it turned great!
eBayWhere did you buy all your parts from? I found the end caps and top step pad second hand but it doesn’t have mounting brackets
This is perfect thank youeBay
Tasca
Then paint matching with Space White Metallic (A3) was another $307.50 on top of that.
That’s all the parts I ordered to complete the swap. The only thing I would do different is spend a couple more bucks for an oem top step pad for the rear bumper.
So if I got these OEM exhaust pieces, it should bolt right up to my 3.5 correct? No modifications? (2021)I went with the OEM Ford Exhaust pipe so I wouldn't have any issues
