5.0Screw22
The part number discussion is getting confusing and I think I can help people sort it out. First, there are two numbers for each part and it seems that people may be confusing the part number with the engineering number. The part number is the number Ford uses to sell the part. That number is on the box, bag, or tag for the part for sale. In this case, a blue Ford Parts tag. The engineering number is the number that is usually stamped on the part, cast or molded into the part, or it is on a decal on the part. On these exhaust pipes, the engineering number is on a white decal wrapped around the pipes. Here is what is on the pipes I purchased:
The driver’s side pipe is Ford part number is ML3Z-5202-H, but the number on the decal around the pipe is the engineering number of ML34-5202-J
The passenger’s side pipe is Ford part number is ML3Z-5202-J, but the number on the decal around the pipe is the engineering number of ML34-5202-K
If you are looking at the pipe on a vehicle, then you are looking at the engineering number on the white decal that surrounds the pipe. This is different from the Ford part number used to buy a part. Notice that the part number use ML3Z and the engineering starts with ML34.
Here is a photo from my passenger side pipe showing both numbers on the same pipe.
Let me toss in one more thing about Ford part numbers vs. engineering numbers: If Ford makes a minor change in a part, they will change the engineering number without changing the part number (if the change is backwards compatible). This is why it is important to make sure you know the difference between the two types of numbers that Ford uses.
