Swapping OEM power running boards for AMP boards?
Wmflyfisher
Wmflyfisher
Wesley
Sep 7, 2023
130
152
Inlet Beach FL
2019 F150
Ahh. I wondered what the issue was. Is your truck lifted? My buddy has the factory power boards and I thought they come out at a really good level but he is at stock height.
Yes with 35’s. The older version deployed lower which was much more comfortable stepping on and for others as well.
astrand1
Alex
Dec 16, 2021
771
556
22 Ford F150 Powerboost 7.2kw
Studio truck driver
I like the idea of maybe seeing if superduty oem steps might work. Since the cab is the same. Maybe they have longer reach. 🤔
superfordman
Troy
Jun 29, 2021
803
770
NE CO
2023 F150 Lariat 501A
Precision Ag Guru
Wmflyfisher
Wmflyfisher
Wesley
Sep 7, 2023
130
152
Inlet Beach FL
2019 F150
If you have the 21+ factory power boards, the super duty boards probably go about 5 inches lower, that was the difference between my factory boards and the SD boards I put on.
@astrand1 @Wmflyfisher
https://www.f150gen14.com/forum/thr...oards-install-a-plug-n-play.13168/post-326966
5” would be great. Your thread is helpful too thanks. Like you I could get a set with the chrome strip but I’m not familiar with wrapping so I’m looking for a black set. Not much luck though.
superfordman
Troy
Jun 29, 2021
803
770
NE CO
Precision Ag Guru
It was stupid simple to wrap the chrome, if you can lay down masking tape you can do this just as easy, here is what I used and worked great. Its held up awesome and no peeling or anything.
https://www.amazon.com/gp/product/B07C5DCZFV/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&th=1
motivology
DK
Aug 5, 2022
144
63
2021 Ford F150 Platinum Powerstroke
Realtor / Entrepreneur
superfordman
Troy
Jun 29, 2021
803
770
NE CO
Precision Ag Guru
That is great to know. Everything bolts right up with SD boards, and it’s plug-n-play? No special instructions?
-DK
Yup, if you already have power boards it should be. You might have to run a DSM self test so the new boards calibrate correctly, but that should be it.
motivology
DK
Aug 5, 2022
144
63
DSM self test? How can I run that?
jonhgauthie
Jon
Nov 4, 2023
Stkn, Ca
2023 Ford Lightning
Carpenter
I need them to deploy lower.
I had a 2019 F-150 with peer boards that were at perfect height for me
My new 2023 are almost 4-5” higher when deployed. Which sucks for me. Any suggestions, wish I would have pulled my old ones off before I traded 2019 in. 😖
Wmflyfisher
Wmflyfisher
Wesley
Sep 7, 2023
130
152
Inlet Beach FL
2019 F150
Swap them for F250 model boards or 2015-2020s. I’m going to do the swap but haven’t pulled the trigger yet.
superfordman
Troy
Jun 29, 2021
803
770
NE CO
Precision Ag Guru
Should have swapped them, would have been plug and play. Super duty boards will be a couple inches lower but are closer to your old ones than the new ones. I can find SD boards left and right on marketplace, F150 boards are a diamond in the rough apparently.
Michael1955
Michael
Aug 23, 2023
Wilson, NC
2022 F150, 2011 Crown Vic
Retired Pharmacist
I tried the extenders…didn’t like them….found a set of 15-20 f150 power running boards….they fit fine…same plug..I just had to reverse the polarity of the power wires. They go down to the proper height
