Swapping OEM power running boards for AMP boards?
10,473
20,148
BUDXR7
Nov 19, 2023
113
108
Massachusetts
2023 XLT 302A PB SCREW 4X4
Has anybody done this? If so, is it pretty straightforward? 23 platinum with factory power running boards. Would like to swap them for Amp boards due to them dropping lower.
I recall seeing somewhere these are not a simple retrofit to a non power step equipped truck. I have a 2023 PB SCREW XLT. Does anybody know if these retrofit painlessly?
superfordman
Troy
Jun 29, 2021
907
889
NE CO
2023 F150 Lariat 501A
Precision Ag Guru
Um... the word retrofit and painless don't belong in the same sentence when referencing these unfortunately, or just depends on your level of painless/skill. I thought it was pretty dang simple all things considered, but I'm probably far from the norm, much less hack & splice like most of the aftermarket options.
https://www.f150gen14.com/forum/threads/ford-oem-power-running-boards-install-a-plug-n-play.13168/
BUDXR7
Nov 19, 2023
113
108
Massachusetts
Well now that we’ve got the word games and semantics out of the way, thank you for the link. It would be nice if there was a write up, rather than one run-on sentence. That said, the referenced thread doesn’t really help. Neither does saying it’s complicated but “im the man so it wasn’t for me”.
There was a thread on the other f150 forum where a user paired the 15-20 oem boards with some amp research wiring harnesses and got it to work perfectly. That was back in 2017 I’m curious if this can be done with the magna’s on the 14th gen non-power-equipped trucks. Looking for an actual answer, not whatever the above was.
Wmflyfisher
Wmflyfisher
Wesley
Sep 7, 2023
142
163
Inlet Beach FL
2019 F150
I think it would be a bit of a challenge with the OEM one’s retrofitting to a truck without power boards but I’m no expert. You would need to do some adjustments in the PCM or with Forscan. Your best bet would be the Amps they are very easy but you won’t get the button and extended length.
superfordman
Troy
Jun 29, 2021
907
889
NE CO
Precision Ag Guru
Can it be done? Yes. Is it easy? Not really. If you want simple plug and play, AMP would be the way to go. If you want to get more crafty and want the cool factory PRB features and integrations, it can be done to add all oem components. You should in theory be able to buy the AMP controller and harness kit for a 21+ and use it to run any 15 and newer OEM boards, since they are all the same design essentially.
Lycan76
Anthony
Mar 26, 2024
34
North Carolina
2022 F150 Platinum
I know this an old thread but i just bought a 22 F150 platinum with a 6" lift and my step does not go low enough for my 5'2" wife... should have thought this through.. has anyone tried adding the 150 running boards to the 250/350 brackets.. mine has the kick switch.. would love to keep it. new guy here been on the other f150 forum since 2017.... nice to meet you guys!
