SM77
New 2023 Platinum PB short bed. Daily driver (pavement only) and will be pulling a 24' ATC race car trailer (total should be around 7500 lbs with everything) come spring and summer (about 6-8 times a year).
Will be using my old Equalizer hitch.
I installed Bilstein 5100s in the rear and then added the RAS HD kit.
The RAS HD added 1.5" to the rear (1mm/white shim) and I will adjust it higher if needed. Haven't tried to hook the trailer up yet since it is buried in some snow.
I did a quick drive after the RAS install and it didn't really make too much of a difference unloaded. It is slightly better planted in the rear, but it has made the front feel more crashy/harsh but that might just be in comparison. Guess the rabbit hole will mean 5100s in the front soon too. (I really don't want to change the height in the front but I do think better damping in the front will help). I recognize that this my first truck and I'm used to German SUVs and a certain level of responsiveness and handling. Then again, towing the 24' trailer with a Mercedes GLS was always slightly over the edge so this truck's capability is where I'm at.
Aside from having to loosen/tighten the RAS and make sure it is centered, I don't see any downsides to removing the rear blocks, right? It should give me back about 1.5" (maybe closer to an 1") and lower the rear back to almost where it was prior to the RAS / stock, but thought I'd check in case I'm missing something. Will probably think about adding the Steeda rear sway bar too.
