Anyone remove rear blocks to do a "reverse level"
Littlefield82
May 13, 2021
30
268
258
Holly Springs, NC
2021 Lariat 502a PB FX4 5.5'
Civil Engineer
I just got off the phone with my local Ford dealer and they quoted $35/per U-bolt for the 2 wheel drive ($140 total) and $8 for replacement nuts. If you have a 4x4 and want to ditch the longer bolts and use 2 wheel drive u bolts it's not a cheap mod. If you want to keep the longer 4x4 u bolts then make sure you have washers and a really long deep socket in order to tighten the nuts as there will be a lot of thread showing on the 4x4 u bolts.
FastHamFreddy
Fred
Dec 3, 2021
67
37
Alabama
2021 Ford F150 XLT
Project Manager
I removed the blocks on my 4x4, dropped it about an inch.
It won't really have any impact on towing, however, you may experience a reverse rake with heavier tong weight. I plan on installing airbag helper springs, simply because my last truck had them, and I really liked how that truck towed my camper.
Here is the process/photos: https://www.f150gen14.com/forum/threads/anyone-remove-rear-blocks.3779/post-109663
Did you need to adjust your headlights when you removed the rear blocks?
12Lariat21
Jonathan
Mar 23, 2021
404
481
55374
2021 Lariat 502A
Engineering Manager
I have a 502A Lariat, so they are auto adjusted anyway, so for me...No.
I wouldn't think that 1" would be enough to change your headlight angle where you would need to readjust it, anyway. But could be something you want to check on.
lilburnedbear
Apr 7, 2023
28
Portland, OR
2021 F150 XLT Crew Cab Powerboost
Underwriter
...The Ford Performance shackles had 24 pages of instructions on how to install by lowering the gas tank. I used the instructions for torquing the U bolts....
Did the instructions provide torque specs for the shackle bolts too?
lilburnedbear
Apr 7, 2023
28
Portland, OR
Underwriter
Ford Performance has a shackle lowering kit that also includes a wedge shaped shim to change pinion angle for driveshaft to be added to spring pack.
Was that for the part number M-3000-HA? The picture on either Summit or Ford Perf Parts doesnt show the wedge. It DOES show it on M-3000-G which is for earlier models. Can you recall which you purchased? THanks
powerboost
Jim
Apr 21, 2021
178
294
Portland, Oregon
retired technician
I never followed through with getting kit so do not know answers. My suspension is still stock. I just repeated info that others had posted.
nezff
Apr 8, 2022
480
361
Louisiana
2022 F150 Lariat 4x4 Supercrew 5.0 Space White
Firefighter
nezff
Apr 8, 2022
480
361
Louisiana
Firefighter
1.5 ford performance shackles. Left blocks in. No shims came with this new version kit.
Ford F-150 Anyone remove rear blocks to do a "reverse level" IMG_20230719_115513_952
Ford F-150 Anyone remove rear blocks to do a "reverse level" 20230710_135918
Ford F-150 Anyone remove rear blocks to do a "reverse level" 20230708_101355
nezff
Apr 8, 2022
480
361
Louisiana
Firefighter
what method did you use to remove top shackle bolts.?
With frame on jackstands, jack up the rear axle until it clears the frame. I dropped my spare tire for for clearance on driver side. There is a wire bundle in the way.
WhiteLightningnshitshadow
Feb 24, 2023
46
538
313
Lead Engineer
No vibrations? Having the same config truck as I do, I assume you have flat blocks too. Mine has settled in a bit and I removed the rear blocks like 700 miles ago. I never experienced vibrations. Thinking about the geometry, I went with removing the rear blocks to lessen the axle wrap and not alter the spring rate instead of shackles. I was originally going to do mild shackles and bocks, but actually liked just the blocks so much that I returned the shackles.
Ford F-150 Anyone remove rear blocks to do a "reverse level" PXL_20230705_022350895
nezff
Apr 8, 2022
480
361
Louisiana
Firefighter
No issues at all. I got roughly a 1 inch drop out of the shackles. Maybe a tad more. Wanted to remove the blocks along with the shackles but not sure if that's asking for trouble(vibrations)
vinnie45acp
Vince
Oct 5, 2023
Virginia, USA
2022 Ford F150 Lariat Sport/Black out/502A
Logistics
I just removed my Blocks, it went really smooth, HOWEVER, when I was done I went and checked my rake on both sides and I have a 2" rake still on Driver side and barely a 1.5" rake on passenger side, I thought maybe I did something wrong, so I went back under and double checked everything and everything seems fine. All my tire pressures are right and the fuel tank extra weight is on the driver side so you would think it would the side lower, not higher. Any suggestions, or anyone having the same issues?
