Zyvin
No, I sure don't. Mine is #1 in the picture with part number ending in -BB (1 3/16"ish), and I have a Crew Cab FX4, short bed (not heavy duty package). These 3 may all be about the same thickness with #2 and #3 being tapered as they are for long wheel base with the base load package and the short wheel base (single cab). I assume #2 and #3 are tapered to adjust the pinion angle on the models that they are used on. If you are looking for a little thicker; I am not sure but maybe the Tremor is taller (1 3/4"?), but someone here would have to verify that, as I am unsure. Here are the notes on those three spacers that I had pictured above:Do you happen to know the different sizes of these blocks?
"1. Install on vehicles with 141 in, 145 in and 157 in wheelbase (all payload packages) and vehicles with 163
in wheelbase with heavy duty payload package only.
2. Install on vehicles with 163 in wheelbase with base payload package. The protrusion on the spring spacer
should face toward the front of the vehicle.
3. Install on vehicles with 122 in wheelbase with"
