Warclok
Hey Mike, can you take a quick pic of where in the engine bay this connector is located? I am having the same issue and want to check tonight as well.I had a similar problem with the “Breaker A Tripped In Bed” warning on every ignition start up. No breakers were tripped. All the bed plugs had power. Neither cabin 120 volt plugs had power. The TSB at the beginning of this thread said to check the harness connection at the dash outlet. The connection was ok. But the other end of the harness located in the engine compartment by the master cylinder, Connector C3412 on Harness #14405 had never been plugged into the main harness. The harness plug protective end cap wasn’t even removed from the harness. Purely an assembly line error. I think assembly line quality control should have seen the error message and corrected the problem. Barring that, I think dealer PDI should have caught this before I picked up the truck. The dealer service manager wanted to kick the truck back to Ford. The dealer tech wanted to fix the truck. Thank goodness for this forum because the dealer technician was lost until I showed him the TSB listed at the beginning of this thread. Even though it didn’t precisely describe my truck’s problem, it was close enough that the dealer tech knew where to pin out the harness and locate the actual problem. Kudos to this forum, and the dealer tech. Not so much for the dealer PDI team, the dealer service manager and the factory QC team. But I love the truck.
